Modular V10 (6.8l)
Banks Transcommand Questions
Old Aug 31, 2007 | 04:13 PM
Tacohead's Avatar
Tacohead
<TABLE><TBODY><TR><TD vAlign=top width="100%">I posted this in the Super Duty forum but had little response so I thought I would try here. I have rescently purchased a 2000 F-250 SD with the V10 and 89K miles. I really like the truck and the only concern that I have is the transmission. I also hate the way it shifts. I have been reading about the Banks Transcommand. I'm not interested in a chip to improve performance but improving the longivity of the transmission is a concern.
Would you recommend the transcommand for a transmission that has 89K miles on it? If so, where is a good place to pick one up? Any other advice would be appreciated.
Thanks in advance,
Kent
</TD></TR></TBODY></TABLE>
Old Aug 31, 2007 | 05:25 PM
rclarke's Avatar
rclarke
The transcommand increases transmission oil pressure in relation to throttle setting. I installed several before I retired. I felt they did a good job since they did little to make the shift harsh under normal driving conditions but made good crisp shifts at higher throttle settings and heavier loads.
Old Aug 31, 2007 | 05:31 PM
Antelope V-10's Avatar
Antelope V-10
Everything I have read and heard about the Transcommand was sumed up perfectly by rclarke.
Old Aug 31, 2007 | 05:57 PM
Tacohead's Avatar
Tacohead
Thanks for the comments! One more question. Would you add a tranny temp gauge to keep and eye on the temp. I usually tow about once a month. The load consist of a trailer with a jeep on it going to the mountains. I estimate the load is around 8000 lbs.
Old Aug 31, 2007 | 07:14 PM
boggerted's Avatar
boggerted
a trans temp gauge is always a good idea, chip or not.
Old Sep 1, 2007 | 12:31 AM
c00nhunterjoe's Avatar
c00nhunterjoe
stay away from the trans command, lots of bad dealing workin for ford, they do nothing under light throttle only hard accel, i just posted on your other topic, so i will repost here this is videos of my homemade shift kit, view your other post or pm me for more info
http://youtube.com/c00nhunterjoe
thedaddycat
Oil & Lubrication
Feb 27, 2008 06:12 AM
LostMayhem
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 9, 2008 12:17 AM
sheranian
15
Sep 18, 2007 10:12 PM
brianstacy
Apr 16, 2007 11:25 PM
randy332
Mar 8, 2007 06:47 AM
