Shoop, Shoop, Shoop
Old Aug 31, 2007 | 01:05 PM
dcara's Avatar
dcara
Shoop, Shoop, Shoop
Thats the sound it has started making when it is first started and idling. It occurs at about a 1 second rate and seems to match the serp belt rate. The sound diminishes to nothing after about 3 minutes. I've inspected the belt and don't see any wear though. However, the belt is original and has 102K miles on it. Ideas?
Old Aug 31, 2007 | 01:12 PM
aldridgec's Avatar
aldridgec
Belts can get noisy and not show any wear. Could also be a bad idler pulley. If you think it is in the belt drive, you need to loosen the belt and check the pulleys for any noise or roughness. If you don't find anything, give the belt a spritz of something like wd40 and see if the noise goes away. If it does, you probably need a new belt.
Old Aug 31, 2007 | 01:24 PM
misterfisher's Avatar
misterfisher
That's the sound my water pump made before opting for early retirement. Take your fan, and wiggle back and forth hard with the belt off. My belt has 190,000 miles on it, and doesn't make a sound, and that is after having antifreeze and everything on it.
Anomic
Car/truck Buying Advice
Mar 5, 2011 08:37 PM
jan_anna
General Automotive Discussion
Sep 18, 2006 04:22 PM
preppypyro
16
Feb 26, 2006 04:51 PM
Mike G
Colorado Chapter
Feb 14, 2004 09:30 PM
Steve
Exhaust Systems
Jan 4, 2000 10:01 PM
