Code P1221 - Replace ICP?
Old Aug 31, 2007 | 12:42 PM
CowboyUp1387's Avatar
CowboyUp1387
One of my fleet trucks- '95 F350 PSD Auto- thing runs like garbage and you have to rev it up in order to get it to idle. Idle sounds like all the injectors are randomly firing is the best way i could describe it. Then you touch the throttle and it revs up real quick, like i can't just rev it to 1200, it will go strait to 2000 or so. The funny thing is the check engine light will come on after a little bit of driving and then the thing runs great, like it should. The code i pulled was P1211- Injector control pressure above/below desired. I looked at the wiring and connector on the sensor, and everything looks ok. Can i test this? Or just replace the sensor for $170?! Thanks for any help!!!
Old Aug 31, 2007 | 04:50 PM
c00nhunterjoe's Avatar
c00nhunterjoe
when its running like crap unplug the sensor, if it idles good then replace the sensor
schlik83
Aug 8, 2020 08:21 AM
chrisjrosenbohm
Apr 4, 2017 03:31 PM
Mrdbraun
Modular V10 (6.8l)
Feb 8, 2017 09:19 PM
Mrdbraun
May 17, 2016 11:19 AM
quesey
Jan 29, 2013 01:31 AM
