Shelby Intake
Old Dec 31, 2002 | 07:04 PM
Unglued's Avatar
Unglued
Shelby Intake
I have a chance to buy this awesome aluminum intake off of a guy. It is currently on a 390 in a truck. It is a high rise intake and says Shelby on it. Does anybody know what this thing is and what it is worth? Also it has a set of the old short cast iron headers on it too. Thanks for the help. I haven't got the numbers off the heads yet, but I as wondering if they and the intake are high rise or tunnel ports but I am not sure. THe exhaust ports have ribs on the top of them that my 352 heads don't. Any help in the speculation would be appriciated. THanks
Old Dec 31, 2002 | 07:51 PM
Ratsmoker's Avatar
Ratsmoker
Shelby Intake
Is it a single or dual plane intake. I want to say that they are copies of the edelbrock intakes. His single plane looks identical to the Victor with the exception that carrol claims a 3000 - 8500 rpm range instead of a 4500 - 8500 like the ebrock. If he is wanting a lot of money for it you are probably just paying for a name.
Old Jan 1, 2003 | 09:49 AM
dinosaurfan's Avatar
dinosaurfan
Shelby Intake
I guessing the intake is an Edelbrock with Shelby's name on it....I think Shelby sold Edelbrock F427 manifolds with his name on them in the mid 60s...if thats what it is, an F427 manifold is usually good for 300$ or so....and the headers- some of the concours restoration guys like those cast iron shorties for galaxies, maybe look on Ebay and see what are they selling for. DF
Old Jan 1, 2003 | 11:29 AM
Mike W's Avatar
Mike W
Shelby Intake
I have an aluminum manifold that has the Ford logo on the top in front of the carb. Any thoughts as to who made it?
Old Jan 1, 2003 | 07:21 PM
davidoldfordfan's Avatar
davidoldfordfan
Shelby Intake
The high rise and tunnel port heads will only fit on 427 blocks due to valve size.
In addition, shelby never sold any intakes for those heads.
david
Old Jan 2, 2003 | 06:19 PM
Unglued's Avatar
Unglued
Shelby Intake
New news. I looked for some casting numbers off the Shelby intake and found none. But I did find some numbers off the head. I think I have narrowed it down to two possibilities. I think they are either medium riser or high riser 427 heads. Here's what I can read of the number. I can read everything but the suffix which tells the revision. Here goes...C4AE-6090-?. THe "?" looks like a backwards D to me so I am not sure what it is supposed to be. Now, If I am correct this can't be a 390 block these heads are on if these are really 427 heads since the bore size is way to different even if the 390 block has notched cylinder walls. What do you guys think. I know it is not an HP block because there are no ribs on the side of the block and it does have the common 352 stamp on the front of the block under the drivers side head. Where are the casting numbers on the block located at. This is very intriging and thanks alot to all of you for the help.
Old Jan 2, 2003 | 07:21 PM
BB's Avatar
BB
Shelby Intake
I bet the heads are C4AE-G. On some heads the G is partly covered on the right-side by the screw head so all you see is the left side of the G.
The Shelby alum. intakes were sold over-the-counter. Sometimes they said Shelby on them, other times Ford. Good intakes but nothing exotic.
Barry
Old Jan 3, 2003 | 01:26 AM
Scotty1's Avatar
Scotty1
Shelby Intake
I would agree with Barry on the heads. The intake seems to nothing special, unless you are a big Carroll Shelby fan. If he wants as much as was mentioned earlier then I would lean toward the Blue Thunder or RPM intake.
Scotty
Old Jan 4, 2003 | 01:50 PM
davidoldfordfan
Shelby Intake
C4AE heads (whether G or not) are basic 64-65 352-390 heads.
Medium Riser heads are C5AE-6090F, Tunnel Port are C70E or C8AX. High Rise are C4AE-6090-F but again, Shelby never made a manifold for HR heads and no the only 427 heads not requiring a 427 block (do to bore/valve size) are the C3AE-6090-D,G,H,J
Old Jan 5, 2003 | 09:18 AM
fomocoloco's Avatar
fomocoloco
Shelby Intake
how do those cast iron shorty headers fit on that truck? i have a pair and am considering installing them on a 72 f100sb. what year of truck are they on? is clearance an issue? thanks. jim
Old Jan 5, 2003 | 01:15 PM
Unglued's Avatar
Unglued
Shelby Intake
The headers fit fine except that it looks like the frame might be notched out a little for clearance. By the way, is is a 74 3/4 ton 4X4.
Old Jan 5, 2003 | 02:41 PM
OneFine69's Avatar
OneFine69
Shelby Intake
2009kr
May 10, 2018 08:03 AM
Larry85355
49
Dec 31, 2010 02:23 PM
mustange70
30
Feb 13, 2006 11:23 AM
fordtrucksforever
Jul 26, 2004 11:31 AM
shelby lynn
17
Feb 10, 2002 04:13 AM
