Can you explain a little more about identifying a 17. I'm not sure I understood what you said except the you cant tell from the outside. When you get the cover of what do you look for? Is there something different inside? Was the part number you gave the right one for the 17 pump? I just want to make sure I'm clear on what I'm looking for cause I need to get one soon also. Thanks
the 15* pump will have a bearing inside and the 17* will have a bushing in there. Search HPOP in webshots you should be able to find pics of both types. Pretty easy to spot once that cover is off.
if you look you can find them cheaper. i used to have a couple places bookmarked but my computer crashed and i lost it all. i will try to find some cheapies.
you have to shop around and keep your eyes on ebay...
I got mine brand new in box (reman) plus brand new in box IPR
for $360 or so that was a smoking deal, but everybody and their
brother is looking for SD pumps now, getting hard to get a good deal
but they still are out there...
the pump can produce more than 300 psi, but 23000 is way too much, the pcm will dump the ipr at 4000, i will double check my cheat sheet to be sure, but the normal full throttle full load will exceed 3000 easy
