u=joint u-bolt torque
Old Aug 30, 2007 | 08:26 PM
tastyklair's Avatar
tastyklair
What should my u-bolts for the rear driveshaft be torqued to? Haynes says 90-100ft lbs. That seems awfully high to me.
Old Aug 30, 2007 | 08:33 PM
JBradley500's Avatar
JBradley500
until the lock washer flattens out plus 1/8th of a turn
Old Aug 30, 2007 | 09:26 PM
Mil1ion's Avatar
Mil1ion
I doint know where you got that info but it goes by bolt size.
5/16" = 15 ft lbs
3/8" = 17-26 ft lbs
7/16" = 30-40 ft lbs
Old Aug 30, 2007 | 11:43 PM
fasthauler's Avatar
fasthauler
I think we have the u-joint and the differential mixed up. The spring to axle housing U-Bolts are 110-160 ft-lbs. the U-Joint bolts are 8-15 ft-lbs for the 5/16, 17-26 for the 3/8, and 30-40 ft-lbs for the 7/16.
Old Aug 31, 2007 | 12:51 AM
Mil1ion's Avatar
Mil1ion
I didn't .....as you can see
Old Aug 31, 2007 | 01:12 PM
scottie2hottie's Avatar
scottie2hottie
tightened until they snap then go buy new ones and don't make em quite as tight as before LOL
Old Aug 31, 2007 | 08:47 PM
JBradley500
well most people dont use a torque wrench on u-joint bolts....
i got the information from mustang monthly from a few years ago...
Old Aug 31, 2007 | 11:35 PM
fasthauler's Avatar
fasthauler
You would have to have a special kind of a torque wrench. I can barely get a box end wrench on my U-Joints. In 1977 I found one made by Utica and it was about $160.00. $126.00 for the torque wrench and $37.00 for the box end head that fits in it. You would have to buy another head at $37.00 each for each size of box end you needed. I decided that I would just continue using a box end wrench and tighten them up until they were snug. I have been doing this for over 50 years and have never had a U-Joint come loose.
Old Sep 1, 2007 | 06:42 AM
tastyklair's Avatar
tastyklair
OK thanks. What about the front where the bolts just go into the transfer case yoke?
Old Sep 1, 2007 | 03:46 PM
Mil1ion's Avatar
Mil1ion
The same I believe
DHamSTER
Oct 9, 2014 04:45 AM
'94IDITurbo7.3
25
May 14, 2014 08:38 AM
JROB
Mar 13, 2009 01:14 PM
maevans
Mar 15, 2008 07:55 AM
TallPaul
Jul 29, 2001 05:34 PM
