Sponsored by: Auxito
Need help diagnosing an electrical problem
Old Aug 30, 2007 | 05:10 PM
drakul20us's Avatar
drakul20us
I have installed a K&N cold air intake and Powerdyne throttle body spacer in my truck and ever since then I am getting a DTC of air/fuel mixture is too lean in both banks. Also my truck does no want to accelerate as fast as it used to, having a hard time getting to 3+RPM, and MPG went down the toilet to about 9. I have narrowed the problem do the electrical signal being sent to my MAF sensor. I have probed the wiring harness of a MAF sensor and it is at 14volts, in the manual it is specified that the voltage should be 2.0v at open throttle. My question is what would cause such a huge differential and how would I go about fixing it. Thank you.
2000 F-150
4.6L v8
142,000
Old Aug 30, 2007 | 06:26 PM
screwy's Avatar
screwy
One, clean the MAF sensor, If the K&N was over oiled it can coat the sensor in oil. 2nd, Check for air leaks after the MAF Sensor. I’ll look into the MAF signal values, but I suspect that may not be the problem given your recent modifications.
Blue Rebel
Nov 7, 2011 04:20 AM
khadma
1997 - 2003 F150
Sep 24, 2011 11:01 PM
AndeyHall
Jul 6, 2011 09:32 AM
ozoner
3.0L V6
May 2, 2006 10:48 PM
rleptrone
1997 - 2003 F150
Jan 21, 2005 08:13 AM
