Sponsored by: Auxito
Clean engine - dirty misfires!
Old Aug 30, 2007 | 07:27 AM
luv2pla's Avatar
luv2pla
After changing my oil recently, I decided to use a little engine degreaser on the engine to clean it up a little. BAD IDEA! After letting it sit overnight, the next day I had a terrible misfire. I took it to have the codes read and it turns out that cylinders 3 and 6 showed misfires. This is a 5.4 in a '97 Expedition with 190,000 miles. The plugs were changed recently (less than 20,000 miles ago), along with the wires/boots. A couple of the COP's have also been changed over the past few years.
I have a few questions:
1. Should I replace the two plugs that are on the cylinders showing misfires?
2. How can I tell if it's the plugs/boots/arcing, or the COP that is the problem?
3. What's the best way to dry out these components? Air hose, hair dryer, etc?
4. I plan to put dielectric grease on the boots, etc. Is that OK to do?
Old Aug 30, 2007 | 08:42 AM
ranger88a's Avatar
ranger88a
Pull out the coils and blow out the plug holes. As long as you haven't run it too long all should be fine.
Old Aug 30, 2007 | 09:27 AM
luv2pla's Avatar
luv2pla
I did run it for about 20 - 30 miles to get to a place to read the codes, etc. I guess I won't know until I try it.
How about testing the coils? Any easy way to see if one is good or not? I read about switching them from one cylinder to another, but without a code reader, I'm afraid a miss on one cylinder will feel like a miss on another. I do have a thermal instrument that I can read exhaust temperatures that could tell if a cylinder is dead or not.
Old Aug 30, 2007 | 09:37 AM
LxMan1's Avatar
LxMan1
Welcome to the forum
No real good way to test them. Pull all of the coils, blow out the plug pockets and install dielectric grease on the boots before reinstalling, it should be fine.
Old Aug 30, 2007 | 01:55 PM
ncranchero's Avatar
ncranchero
These engines DO NOT like to be washed! Pull the COP's & blow everything off with compressed air. A good spray of brake clean and another blow for good measure might be a good idea too. I think you'll find it's just wet.
Old Aug 30, 2007 | 02:31 PM
luv2pla's Avatar
luv2pla
I'm going to give the "blow-and-go" method a shot. Hopefully that will work. This engine has been really picky with these misfires. I've replaced two coils and 11 plugs since last October trying to cure it's ills!
Old Aug 30, 2007 | 02:38 PM
ncranchero's Avatar
ncranchero
Boots seem to be a big problem area too. My '98 F150 has wires but my '98 Crown Vic had COP's. My uncle had a '01 Screw and now has a '03 reg, both of which gave problems after he cleaned the engines.
Old Aug 30, 2007 | 03:52 PM
luv2pla's Avatar
luv2pla
I replaced all 8 boots in January, too! It's been quite the adventure!
Old Aug 30, 2007 | 07:24 PM
luv2pla's Avatar
luv2pla
Well, I did some swapping around of coils, etc. and isolated it to the two coils. I replaced them one at a time, and it was fixed. I guess they were so old that the water just finally did them in.
thanks for the forum help!
