cant get bolt on idle pull out!
Old Aug 30, 2007 | 01:13 PM
79f-250custom's Avatar
79f-250custom
well shoot.
have a bad squeek on one of my pullys. so i was pulling them off for inspection and when i was trying to pull the very upper idle pully off. i striped the alan head on it and cant get it out now!
how should i get the damn thing out now?
thanks
Mitch
Old Aug 30, 2007 | 01:52 PM
ruger761's Avatar
ruger761
well thats always a good question when that happens. sometimes you can beat a larger allen in. if that doesnt work you might have to drill a hole in the bolt and use an "ez-out" tool to get it out. you can pick them up at any autoparts store. the trick is getting the hole drilled in the bolt. good luck if your liek me i get real mad at it real fast.
Old Aug 30, 2007 | 05:22 PM
Action4478's Avatar
Action4478
Originally Posted by 79f-250custom
well shoot.
thanks
Mitch
Try welding a hex nut to the bolt....the heat will also help.....
Old Aug 30, 2007 | 06:03 PM
Cuda_jim's Avatar
Cuda_jim
Take another look at the bolt, mines a torx head, not an allen.
Old Aug 30, 2007 | 06:45 PM
1997F-350's Avatar
1997F-350
channel locks, or tap it off of the bearing. the bearings are 6203 2 rsj's at napa cost like 10 bucks each.
Old Aug 30, 2007 | 06:56 PM
trashman2500's Avatar
trashman2500
i most certain there torx head cuase mine was i had to replace mine today it was sittin crooked and i know it wasnt allen
Old Aug 30, 2007 | 11:24 PM
mohead1's Avatar
mohead1
I replaced one of mine just a month ago and it was definately Torx....matter of fact had a hell of a time getting a socket/ratchet in there (it was the top one). I pulled the fan cowling bolts and moved the cowling up a few inches to allow getting in to the bolt. It was a 45 maybe?? I know for sure it was Torx.
BigMo
Old Aug 30, 2007 | 11:52 PM
97REDPSD's Avatar
97REDPSD
Knock or cut pulley off so you can get to the bolt. remove it with visegrips or small pipe wrench.
Old Aug 31, 2007 | 10:21 AM
Neal 97 250's Avatar
Neal 97 250
LOL. Sledge hammer amy work
Old Aug 31, 2007 | 10:25 AM
c00nhunterjoe's Avatar
c00nhunterjoe
aw, you named it
Old Aug 31, 2007 | 10:29 AM
Alaskan 350's Avatar
Alaskan 350
When I changed mine on a 96 last winter it was a 50 Torx
Old Aug 31, 2007 | 11:53 AM
andywe's Avatar
andywe
Mine was torx on the idler pulleys, and Hex on the tensioner pulley assembly. Just FYI guys.
Old Aug 31, 2007 | 12:39 PM
79f-250custom
yes im sorry its a torx not an alan. and i was useing a torx when trying to remove. and i was using a standley torx bit set and i just have to ask how is standlys tools. i like them but not there torx bits.
well ne ways i couldnt get to my truck. i have been working on my buddys chevy that has no power to motor but everywhere else. maybe tonight i can get to it.
i think i will try to weld a nut on the end of it and see how that works.
Mitch
kyle j
Feb 5, 2017 06:43 PM
IHateCommieCars
Jun 29, 2015 06:27 PM
Zac2zac2
42
Feb 27, 2014 04:45 PM
Mark-I6
May 13, 2006 05:10 PM
cjbronco
Jan 14, 2005 07:16 PM
