Twin Stick NP205
Old Aug 29, 2007 | 05:56 PM
YoungMT Hick's Avatar
YoungMT Hick
Twin Stick NP205
some one want to point me out what the reason is to twin sticking a divorced NP205. what are the benefits? why should you do this? just wondering thanks
Old Aug 29, 2007 | 08:11 PM
mark a.'s Avatar
mark a.
You can operate the front axle separetely from the rear axle.
Old Aug 29, 2007 | 08:31 PM
75F350's Avatar
75F350
not limited to divorced 205's nor is it limited to just 205's.
Also provides the option of 2wd low range.
Old Aug 29, 2007 | 09:41 PM
YoungMT Hick
so do you just run a stick to each shift tube( wrong termonalage) so you can shift each on seperate. cuz right now the shifter is attached to a rod that is connected to both shift tubes by a flat piece of metal. so do you remove the flat connector and run a rod from each shifter to each shift tube? got it????
Old Aug 29, 2007 | 10:08 PM
75F350's Avatar
75F350
Some modifications have to be done to the 'shift rails' as well, but you have the concept.
Old Aug 29, 2007 | 11:07 PM
YoungMT Hick
what mods would those be or could you steer me towards a thread will all the info
Old Aug 29, 2007 | 11:32 PM
75F350's Avatar
75F350
here you go man....
http://ivanribic.clubfte.com/page2.html
Old Sep 1, 2007 | 11:07 PM
YoungMT Hick
hey thanks man one question you can only twin stick with th t cases that had 4hi 4lo n 2hi right not the 2 or 4 ones get it?
Old Sep 1, 2007 | 11:30 PM
75F350's Avatar
75F350
Afraid I am not quite following the question.
Old Sep 1, 2007 | 11:37 PM
YoungMT Hick
ok the f250 of my dads the np205 has 4low then Nuetral then 2 High then 4 High. the Transfer case in my truck has only 4 wheel drive and 2 wheel drive. do you have to have a transfer case like the 205 (with all the geras) to install a twin stick? Is my transfer case just a power splitter preety much
Old Sep 1, 2007 | 11:48 PM
75F350's Avatar
75F350
Ahhhh, you have a D21 single speede case. That only has 4wd, and 2wd, and does not have a low range. pretty sure there is nothing really available for the 21. Gonna be a good idea to install some sort of two speed case in there, before you consider any sort of twin stick modification.
Anyway, a second stick would really have nothing to control since there is no low range. Maybe just front output, but I have never had one apart. Since they are not very desireable, I would imagine many others have never tried this modification on these units either.
Old Sep 2, 2007 | 12:10 AM
YoungMT Hick
well ya i thought so only thing its good for is just knowing you can slam it into 4 whenever instead of the gears. so will the 205 take the same marriage yoke as the 21. the piece from the np435 to the tcase.
Old Sep 2, 2007 | 09:27 AM
75F350's Avatar
75F350
https://eshop.advanceadapters.com/cc...d-fullsize.htm
See if this helps a little. Might get you pointed in the right direction.
Most of the NP, and BW t-cases used the common 6 bolt pattern, but the D21 had a funky 4 bolt pattern similar to the 2wd models, so i do believe there are some differences, but I am not 100%. I do know that there were 205's behind 435's so it is a possible modification, I am just not sure how much is involved. I am assuming that this is a married unit and not remote. Remote (divorced) makes it easy. No ad adapters just a slight change to the driveshaft(s).
Old Sep 2, 2007 | 04:33 PM
STGFordCrazy04's Avatar
STGFordCrazy04
75, you beat me to posting that link. That is the best "how-to" of a twin stick Ive ever found.
BTW, where did Ivan go?
pintoches
Offroad & 4x4
18
Jan 22, 2012 01:18 PM
MUDLIZARD
Jul 24, 2011 10:45 AM
1977Custom
30
Oct 24, 2008 10:36 AM
ozzy460
Offroad & 4x4
Apr 7, 2008 01:56 AM
MBBFord
Offroad & 4x4
Apr 18, 2007 12:57 PM
