Fram Filter
Old Aug 29, 2007 | 12:11 PM
indebt's Avatar
indebt
Fram Filter
anyway to change out my oil filter without draining the oil? I know impossible but with all the talk of the fram filter being POS's I went under to check and the wally wolrd guys got me, they put one in instead of the motorcraft they had sitting there. Guess I will go bitch, since it was in TX I dont know what these bozo's will do. Is there any documentation I can use to help my case on these filters sucking?
Old Aug 29, 2007 | 12:19 PM
Tenn01PSD350's Avatar
Tenn01PSD350
You can change the filter without changing the oil. You will lose some oil but the bulk of it is in the pan. You will just need to fill the filter and top off the pan. Do you know what kind of oil they put in, for sure?
Old Aug 29, 2007 | 01:24 PM
indebt's Avatar
indebt
yeah they used rotella synthectic 5w40 2 guys brought out 16 bottles of it, and when I came back when they were done there were empty bottles in the trash can by mytruck that werent before. I just never thought make sure they had the right filter. I will go buy one and change it tonight thanks!
Old Aug 29, 2007 | 01:51 PM
Tenn01PSD350
I don't want to insult your intelligence, but there will be quite a bit of drainage so you will need a pan. I predict a minimum of 2 qts.
Old Aug 29, 2007 | 02:01 PM
indebt's Avatar
indebt
cool will do tonight and see whats up, thanks TENN
Old Aug 29, 2007 | 07:16 PM
powerstroke1869's Avatar
powerstroke1869
so dont use fram oil filters ive been using them lately whats the difference between the two
Old Aug 29, 2007 | 07:38 PM
Tenn01PSD350
Apparantly they have a bad rep from somewhere I cannot remember. I have used them in the past in other vehicles with no problems, but this one has had strictly Motorcraft since I have had it.
Old Aug 29, 2007 | 10:24 PM
Gevans17's Avatar
Gevans17
Fram
Been using them for 20 years every 3-4 months without any problems that I can tell. I do prefer the Motorcraft 820 on the Expy, but have used Fram on my other vehicles for years.
Old Aug 29, 2007 | 10:31 PM
powerstroke1869
hmm i duno havent had any problems yet with fram so i guess ill stick with them unless if someone can tell me why they are bad i duno ill try motorcraft once i guess wouldnt hurt
Old Aug 30, 2007 | 09:09 AM
firemediceric's Avatar
firemediceric
I've used Fram filters for years and have never seen any problem. If you look here:
http://theoildrop.server101.com/foru...gonew=1#UNREAD you will see that Fram filters are not real popular. I now avoid them when I can, but I don't treat them like the plague as some would have you do. I now use an Amsoil EaO99. Not cheap, but I've heard real good things about it.
Although you will lose about a quart of oil that is in the filter, you can reduce the amount that may continue to drip from the filter mount. Remove the oil fill cap, place a clean rag over the hole, put a shop vac to the oil fill. This will apply a slight vacuum to the crank case and the negative pressure will decrease the amount of oil that drips out.
I once needed to change the washer on an oil drain plug in the pan. I followed the above method and barely lost a drop of the fresh oil.
Old Aug 31, 2007 | 04:19 PM
rbaker6336's Avatar
rbaker6336
[QUOTE=firemediceric] I now use an Amsoil EaO99. Not cheap, but I've heard real good things about it.
QUOTE]
I also use the amsoil filter is supose to have superior filtering
Old Aug 31, 2007 | 05:09 PM
Izzy351's Avatar
Izzy351
There's more than a quart in there. Closer to two. Also, I think some drains out of the cooler, too. I usually pierce the bottom of the filter and let it drain -- MUCH easier than having it run down the side of the filter, then having to deal with a very full and HEAVY oily filter.
Here is a study of oil filters (not for our trucks, but you can infer what you like about Frams):
http://minimopar.knizefamily.net/oilfilterstudy.html
Joe
Old Aug 31, 2007 | 06:36 PM
poppie's Avatar
poppie
what type of filter wrench do you have to get that filter off,i've been to napa and auto zone and can not find one that fit's a motorcraft 820 filter,I have the long handel SK that fit's the FL1A motorcraft but it look's like it will be impossible to swing the handle,was looking for the type that you use with a rachet extention that fit's the end of the filter (cup type) but motorcraft has the notche's in the end and cup type wrenche's are made for the filter's with the hexogon flat spot's like AC'S,fram,walmart,pennsoil ect,thank's ahead of time,getting close to oil change time.
Old Aug 31, 2007 | 06:49 PM
indebt's Avatar
indebt
just go to lowes and get a rubber strap that plumbers use works great about $3
Old Aug 31, 2007 | 07:20 PM
poppie's Avatar
poppie
don't think so on a 2007 expy,no room to swing a handle,that why i'm looking for the cup type with a long extention.
