ShiftPlus electronic Shift Improver
Old Aug 29, 2007 | 10:41 AM
TheTowingCowboy's Avatar
TheTowingCowboy
Ok I've looked at it, and it' 41.00 dollars from summit. Ok I would like something that would make the automatic in my truck do alot better. Now will this fit my truck, and how hard is it to install? Oh to refresh my truck is a 1995 F-150 Eddie Bauer Extended Cab w/ 5.0 and no other mods to my knowledge other than a cone filter.
Thanks in advance,
JP
Old Aug 29, 2007 | 10:45 AM
Blurry94's Avatar
Blurry94
E4OD transmission?
Old Aug 30, 2007 | 02:15 PM
TheTowingCowboy
Ok I'll take that, I don't know, then again why don't I just look in the Haynes manual. Thnx man.
Old Aug 30, 2007 | 03:31 PM
Skandocious's Avatar
Skandocious
Huh? Did I miss something? Matt was asking what kind of transmission you have... E4OD, AODE, AOD, C6, 4R100, etc etc. What is your transmission?
Old Aug 30, 2007 | 04:28 PM
flareside_thunder's Avatar
flareside_thunder
Haynes won't tell you jack ***** bout what tranny is in your truck...crawl under and look......the pans are different and an E4OD is much bigger than an AODEwhich is what I have.
Old Aug 30, 2007 | 05:05 PM
Skandocious
Direct from the LMC Truck Catalog.
Old Aug 30, 2007 | 05:11 PM
flareside_thunder
I thunk them purdy lil pictures looked familiar.....
Old Aug 31, 2007 | 10:23 AM
TheTowingCowboy
Well how can I tell what it has. I don't know trannys. Is there somewhere on the truck i can look to see what i got? Thnx.
Old Aug 31, 2007 | 10:35 AM
Skandocious
Well I posted that diagram for one... You can check your pan bolt pattern against it...
Or you can look on your door tag and post to the TRANS code for us to decipher for you.
twwtruck
Aug 17, 2011 08:32 PM
Fatstrat
Aug 24, 2009 11:33 AM
Kuskoal
May 16, 2007 09:01 PM
rebel_ford4x4
Mar 5, 2004 03:06 PM
