after transmission flush job- concern...advice?
I dropped my baby at Fords for transmission flush ($150) and i just got home i want to double check the fluid level by the dipstick and i was shocked that I believe they WAY OVERFILLED ATF in it.
Before i blow the lava out of my body at Ford, so how do the correct way to check level dipstick ??
What kind of fluid is it suppose be in it? the paper work said ATF
Big thanks!
YOMAN!
Big thanks!
YOMAN!
on
From the owners manual...
Automatic transmission fluid expands when warmed. To obtain an
accurate fluid check, drive the vehicle until it is at normal operating
temperature (approximately 20 miles [30 km]). If your vehicle has been
operated for an extended period at high speeds, in city traffic during hot
weather or pulling a trailer, the vehicle should be turned off for about 30
minutes to allow fluid to cool before checking.
1. Drive the vehicle 20 miles (30 km) or until it reaches normal operating
temperature.
2. Park the vehicle on a level surface and engage the parking brake.
3. With the parking brake engaged and your foot on the brake pedal,
start the engine and move the gearshift lever through all of the gear
ranges. Allow sufficient time for each gear to engage.
4. Latch the gearshift lever in P (Park) and leave the engine running.
5. Remove the dipstick, wiping it clean with a clean, dry lint free rag. If
necessary, refer to Identifying components in the engine compartment
in this chapter for the location of the dipstick.
6. Install the dipstick making sure it is fully seated in the filler tube.
7. Remove the dipstick and inspect the fluid level. The fluid should be in
the designated area for normal operating temperature or ambient
temperature.
Low fluid level
Do not drive the vehicle if the fluid
level is at the bottom of the dipstick
and the ambient temperature is
above 50°F (10°C).
Correct fluid level
The transmission fluid should be checked at normal operating
temperature 150°F-170°F (66°C-77°C) on a level surface. The normal
operating temperature can be reached after approximately 20 miles (30
km) of driving.
You can check the fluid without driving if the ambient temperature is
above 50°F (10°C). However, if fluid is added at this time, an overfill
condition could result when the vehicle reaches normal operating
temperature.
2006 F-150 (f12)
Owners Guide (post-2002-fmt)
USA (fus)
Maintenance and Specifications
page 305
Transmission fluid................
(4R70E and 4R75E)
Motorcraft MERCONV ATF2
XT-5-QM MERCONV
Ensure the correct automatic transmission fluid is used. Transmission
fluid requirements are indicated on the dipstick or on the dipstick
handle. Check the container to verify the fluid being added is of the
correct type. Refer to your scheduled maintenance information to
determine the correct service interval.
Some transmission fluids may be labeled as dual usage, such as
MERCON and MERCON V. These dual usage fluids are not to be used
in an automatic transmission that requires use of the MERCON type
fluid.
2006 F-150 (f12)
USA (fus)
page 317
Hope this is the info you're looking for.....
temperature.
temperature.
Low fluid level
above 50°F (10°C).
Correct fluid level
km) of driving.
temperature.
2006 F-150 (f12)
USA (fus)
page 305
(4R70E and 4R75E)
XT-5-QM MERCONV
fluid.
2006 F-150 (f12)
USA (fus)
page 317
Originally Posted by DJR 17
I agree that a transmission flush is way beyond the dealers skill level. BTW when should the tranny service or flush be done?
Oops didn't mean to offend anyone, and sorry to paint all dealer mechanics with a broad brush. I just have had way too many bad experiences with dealerships and crappy service. It just happened again the day of my original post. Nothing like paying for a warranty issue after being lied to by the service dept. Ford just lost another customer..
Thats ok as long as you have a converter drain. The newer trans don't, so we do flush them to remove all old fluid. As for the filter, a trans filter shouldn't ever become plugged unless you have an internal problem. Not judging on either way to do it, both work well and is just a personal preference. Thanks for the reply DJR 17, I truly suggest smaller dealerships, we have to be accomodating to our customers. I do know some dealerships aren't.
