after transmission flush job- concern...advice?
I dropped my baby at Fords for transmission flush ($150) and i just got home i want to double check the fluid level by the dipstick and i was shocked that I believe they WAY OVERFILLED ATF in it.
Before i blow the lava out of my body at Ford, so how do the correct way to check level dipstick ?? What kind of fluid is it suppose be in it? the paper work said ATF Big thanks! YOMAN! |
From the owners manual...
Automatic transmission fluid expands when warmed. To obtain an accurate fluid check, drive the vehicle until it is at normal operating temperature (approximately 20 miles [30 km]). If your vehicle has been operated for an extended period at high speeds, in city traffic during hot weather or pulling a trailer, the vehicle should be turned off for about 30 minutes to allow fluid to cool before checking. 1. Drive the vehicle 20 miles (30 km) or until it reaches normal operating temperature. 2. Park the vehicle on a level surface and engage the parking brake. 3. With the parking brake engaged and your foot on the brake pedal, start the engine and move the gearshift lever through all of the gear ranges. Allow sufficient time for each gear to engage. 4. Latch the gearshift lever in P (Park) and leave the engine running. 5. Remove the dipstick, wiping it clean with a clean, dry lint free rag. If necessary, refer to Identifying components in the engine compartment in this chapter for the location of the dipstick. 6. Install the dipstick making sure it is fully seated in the filler tube. 7. Remove the dipstick and inspect the fluid level. The fluid should be in the designated area for normal operating temperature or ambient temperature. Low fluid level Do not drive the vehicle if the fluid level is at the bottom of the dipstick and the ambient temperature is above 50°F (10°C). Correct fluid level The transmission fluid should be checked at normal operating temperature 150°F-170°F (66°C-77°C) on a level surface. The normal operating temperature can be reached after approximately 20 miles (30 km) of driving. You can check the fluid without driving if the ambient temperature is above 50°F (10°C). However, if fluid is added at this time, an overfill condition could result when the vehicle reaches normal operating temperature. 2006 F-150 (f12) Owners Guide (post-2002-fmt) USA (fus) Maintenance and Specifications page 305 Transmission fluid................ Automatic transmission (4R70E and 4R75E) Motorcraft MERCONV ATF2 XT-5-QM MERCONV Ensure the correct automatic transmission fluid is used. Transmission fluid requirements are indicated on the dipstick or on the dipstick handle. Check the container to verify the fluid being added is of the correct type. Refer to your scheduled maintenance information to determine the correct service interval. Some transmission fluids may be labeled as dual usage, such as MERCON and MERCON V. These dual usage fluids are not to be used in an automatic transmission that requires use of the MERCON type fluid. 2006 F-150 (f12) Owners Guide (post-2002-fmt) USA (fus) Maintenance and Specifications page 317 Hope this is the info you're looking for..... |
GEEZ why didnt i think of that manual book...duh me... i checked it and its about 1/4 high in hot range.
whats normal range on dipstick read? cold/hot ? Thanks! YOMAN! |
Man that is one service I would never pay Ford for. They are just too stupid to do it right and it is so important. I feel bad that you even have to worry about it.
I agree that a transmission flush is way beyond the dealers skill level. BTW when should the tranny service or flush be done?
ok i got everything took care of it. i brought it back to Ford and complained about it..they drained some fluid out and its good level now.
YOMAN! |
Way beyond my skill level? I do take offence to that reference!! I do come here to try to help and it seems some feel I'm not qualified! If it's beyond my skill level, why are you here if you know so much!!
Because of dealers terrible service like listed above. I am sure you are very qualified but the customer service just kills you guys. And the overpriced parts,labor,etc..
So you catagorize all techs at a dealership anywhere as being stupid? I understand there are bad techs and dealers but thats the case anywhere. Take your vehicle to wallmart and see if they have the training and experience I have!
Next time, i would just do it yourself, cheaper. no i am not dogging on dealerships, its just sometimes its a little pricy. :)
Thank you BillC.And I do understand the price issue. So I'm not knocking anyone for going elsewhere. Just want a few people to understand we aren't all the same some of us do take pride in our work!!
Oops didn't mean to offend anyone, and sorry to paint all dealer mechanics with a broad brush. I just have had way too many bad experiences with dealerships and crappy service. It just happened again the day of my original post. Nothing like paying for a warranty issue after being lied to by the service dept. Ford just lost another customer..
I don't believe in the flush mainly since it does not address the filter. I have my pan dropped, filter replaced and torque convertor plug pulled and drained.
Thats ok as long as you have a converter drain. The newer trans don't, so we do flush them to remove all old fluid. As for the filter, a trans filter shouldn't ever become plugged unless you have an internal problem. Not judging on either way to do it, both work well and is just a personal preference. Thanks for the reply DJR 17, I truly suggest smaller dealerships, we have to be accomodating to our customers. I do know some dealerships aren't.
