Help!! Hard Shifting / Speedometer Jumping
Old Sep 21, 2007 | 01:18 AM
dirtleg's Avatar
dirtleg
If your TPS (potentiometer on drivers side of IP) is too advanced it will cause your transmission to hold on to the lower gears longer. It is telling your transmission controller how much throttle is being used.
If after fixing your speedo drive gear you are still having shifting issues I would look there.
Old Sep 28, 2007 | 12:07 PM
rcrane511's Avatar
rcrane511
That did it, thanks everybody for your help. I really appreciate it.
Thanks,
Rob
Old Sep 28, 2007 | 01:41 PM
David85's Avatar
David85
Thanks,
Rob
So is it working now?
Old Sep 28, 2007 | 02:25 PM
rcrane511's Avatar
rcrane511
Yup, works like new!!! Thanks Dave for all your help
Old Nov 30, 2007 | 08:10 PM
Purcell McCue's Avatar
Purcell McCue
I'm having the exact same problem, speedo is jumping, shifting erratic. I have replaced the speedo cable and the vss, gear is pink and does not appear to be worn. Is the gear (drive) in the transfer case plastic also, or is the drive gear metal? If it is plastic I will get both the drive and driven gear before taking the transfer case open. I have not replaced the sensor on the rear diff should I do this first as it is easier to access.
Tks
Old Nov 30, 2007 | 09:03 PM
David85's Avatar
David85
Tks
If you have a cable, then the sensor on the diffy will not affect the tranny (its used exclusively for the abs on those years of trucks). Yes, the drive gear as well as driven gears are both plastic, and fairly cheap to replace.
Old Dec 1, 2007 | 06:48 AM
Purcell McCue
Many thanks for the information, I will get both plastic gears this week and install, will let you know how it goes.
Old Dec 21, 2007 | 12:38 PM
Purcell McCue
Got the gears and replaced them today, fixed all problems with shifting and speedometer jump. Many thanks for all the help I have recieved here. Hope this thread helps you as much. Merry Christmas to all
Old Dec 21, 2007 | 12:57 PM
David85's Avatar
David85
Cool, looks like this a a fairly comon problem, Nice when its a cheap fix.
Old Dec 12, 2021 | 06:26 PM
Ben2Far's Avatar
Ben2Far
4wd High
Question
Thanks,
Rob
Where did you buy the gear in the transfer case? I need to do the same.
Thanks
Old Dec 12, 2021 | 08:05 PM
Wheeler.M1's Avatar
Wheeler.M1
Thanks
14 year old thread LMAO.
Look at Northern tools, they got a lot of stuff. Also Rockauto.com
Old Dec 14, 2021 | 02:44 PM
genscripter's Avatar
genscripter
Thanks
i got my gear from Jegs, but it was 6 years ago. Don't know if Jegs still supplies them
bussy97
Jun 9, 2013 07:09 AM
fifty-two_f1
May 8, 2012 10:20 PM
dnlculver
Sep 12, 2010 09:24 AM
dandy deke
May 2, 2010 03:49 PM
southy7
Aug 25, 2003 11:40 AM
