front end noise
Old Aug 27, 2007 | 06:36 PM
otpracer100's Avatar
otpracer100
front end noise
I have a noise in my front end that is prominent when you jerk the wheel hard from right to left, but not from left to right. Does anyone have a schematic, or breakdown of the front end parts? I am not very savvy in this department.Thanks.
Old Aug 27, 2007 | 07:05 PM
c00nhunterjoe's Avatar
c00nhunterjoe
what kind of noise is this? dont know what a diagram will do for you here, anything you need would be right in front of you when rolling under the truck, check your balljoints and steering components, make sure your spring perches arent working loose(look for rub marks on the frame)
Old Aug 27, 2007 | 07:35 PM
otpracer100
I'm looking for a diagram so when I find a problem I know what the parts are called. Drag link, pitman arm etc.
Old Aug 27, 2007 | 07:39 PM
c00nhunterjoe
Steering Linkage, F-350 4x4 Monobeam Axle
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>N800895-S56 </TD><TD>Nut </TD></TR><TR vAlign=top><TD>2 </TD><TD>N642569-S36 </TD><TD>Cotter Pin </TD></TR><TR vAlign=top><TD>3 </TD><TD>N800895-S56 </TD><TD>Nut </TD></TR><TR vAlign=top><TD>4 </TD><TD>3287 </TD><TD>Tie Rod Adjusting Sleeve Clamp </TD></TR><TR vAlign=top><TD>5 </TD><TD>3E652 </TD><TD>Steering Damper Bracket </TD></TR><TR vAlign=top><TD>6 </TD><TD>3B008-DA </TD><TD>Steering Rod and Link Assy </TD></TR><TR vAlign=top><TD>7 </TD><TD>N806888-S56 </TD><TD>Nut and Washer </TD></TR><TR vAlign=top><TD>8 </TD><TD>N806889-S </TD><TD>Insulator </TD></TR><TR vAlign=top><TD>9 </TD><TD>3E651 </TD><TD>Steering Damper </TD></TR><TR vAlign=top><TD>10 </TD><TD>N801342-S2 </TD><TD>Nut and Washer </TD></TR><TR vAlign=top><TD>11 </TD><TD>5310 </TD><TD>Front Spring </TD></TR><TR vAlign=top><TD>12 </TD><TD>5458 </TD><TD>Spring Plate Spacer </TD></TR><TR vAlign=top><TD>13 </TD><TD>3B008 </TD><TD>Steering Rod and Link </TD></TR><TR vAlign=top><TD>A </TD><TD>— </TD><TD>Tighten to 70-100 Nm
(51-73 Lb-Ft) </TD></TR><TR vAlign=top><TD>B </TD><TD>— </TD><TD>Tighten to 34-48 Nm
(25-35 Lb-Ft) </TD></TR><TR vAlign=top><TD>C </TD><TD>— </TD><TD>Tighten to 115-163 Nm
(85-120 Lb-Ft) </TD></TR><TR vAlign=top><TD>D </TD><TD>— </TD><TD>Tighten to 40-57 Nm
(30-42 Lb-Ft) </TD></TR></TBODY></TABLE>
mpriester
1997 - 2003 F150
Dec 22, 2010 04:17 PM
kupaa
Aug 26, 2007 12:30 PM
Techteach1
Sep 28, 2006 06:03 PM
armyman
Feb 29, 2004 11:37 PM
GAFordFan
Mar 22, 2003 10:05 PM
