noise?
Old Aug 21, 2007 | 04:29 PM
kupaa's Avatar
kupaa
noise?
I have 2002 f-250 4x4 and when i turn left or right i here a clunking sound from my front end and can also feel it lightly in my steering wheel.
Old Aug 21, 2007 | 04:39 PM
Benny2002's Avatar
Benny2002
Check to see if your hubs are locked, maybe?
Old Aug 21, 2007 | 06:21 PM
kupaa's Avatar
kupaa
Not the hubs,auto locking and i can tell when there locked.
Old Aug 21, 2007 | 06:53 PM
Benny2002's Avatar
Benny2002
How many miles on your ball joints, is the truck lifted? Does it get worse when ur in 4x4 maybe u joints? Do you have a steering stabilizer, my bracket once got twisted around a little and it kinda clunked till i straightened it back upright.
Old Aug 21, 2007 | 07:58 PM
kupaa's Avatar
kupaa
miles now 59,000,but i started at about 30,000 when i bought the truck used.everything is stock on the susp.
Old Aug 26, 2007 | 02:28 AM
kupaa's Avatar
kupaa
anybody else want to chime in please.
Old Aug 26, 2007 | 06:22 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Check torsion bar down links and bushings. Jack the front end up and grab the tire at top and bottom and try to move it, if any movement at all , probably the ball joint. Is there any slop in the steering? Could also be a tie-rod end. Do a search on here, you'll find lots of reading on this subject. Hope this helps.
Old Aug 26, 2007 | 06:28 AM
AustinS's Avatar
AustinS
I would start by disconnecting your front sway bar links to try and isolate the noise. If still there w/sway bar disconnected, I would then look at the ball joints. I had upper and lower go bad on driver side at 27K mi. Right side upper and lower at 36K mi.
It could also be the front axle u-joints. Your hubs might be partially engaging. It wouldn't be the first time hub malfunctions stump even the seasoned mechanic on these trucks. I had a noise similar as you describe on turning, but only at full left or right .
good luck and keep us posted to what you find,
Austin
Old Aug 26, 2007 | 09:01 AM
stormyrider's Avatar
stormyrider
The factory ball joints don't hold up very well. I would check them and if they need repalced make sure you insist on the MOOG brand. They hold up a lot better.
Old Aug 26, 2007 | 12:30 PM
kupaa's Avatar
kupaa
mahalo everyone,i will check it out today.
ps... the steering is tight and no play
Alleneoc
WTB - Parts & other
Oct 19, 2012 06:33 PM
navyflyinggreg
Apr 24, 2007 02:04 PM
gotboostido
Mar 18, 2007 06:43 PM
hunter1988
Appearance & Dress-Up
17
Feb 16, 2006 06:01 PM
ekers88
Engine Swaps
Jun 24, 2004 09:25 PM
