4R100 Shift Linkage
Old Oct 31, 2007 | 04:23 PM
mustang_gt_350's Avatar
mustang_gt_350
torx screws?
Old Nov 1, 2007 | 08:31 PM
Mach1's Avatar
Mach1
YES...Two of them..straight up from underneath...
Old Sep 8, 2008 | 01:25 PM
toypuller's Avatar
toypuller
I just dredged this post up as I was trying to fix the "slop" in the gear shifter in my 95 F-150.
After reading it I was able to fix the issue in less than 5 minutes.
Rock on, blast from the past.
Old May 11, 2009 | 05:55 PM
IBGonzo's Avatar
IBGonzo
Thanks for helping me fix a shift lever that wouldn't go into park. Found one of the torx acrews on the floor. That's when I knew your thread would be the answer for the fix. Thanks ot you and Mach 1 for the help.
Old Aug 8, 2009 | 12:29 PM
edcetera's Avatar
edcetera
Sloppy Shifter lever 01 f150
My sloppy shifter in my 01 f150 was easily fixed using your described procedure, in 5 minutes.
I used a tiny amount of blue loktite on each screw to keep them local.
Thank you very much
/ Ed
Originally Posted by Mach1
Marvin, there is a setup in the tech manual, I have done it a while ago, the shifter in a certain gear, weight on the lever, and then adjust..
But this is what I see in some trucks, underneath the dash, on top of steering column is a flange with two torx bolts, They come lose and the shifter gets a huge amount of slack in it, check/tighten the two screws, its hard to reach, if you can look up there and wiggle the shifter and you can see them..
Hope this helps.
Old Mar 9, 2010 | 05:25 PM
tholt34's Avatar
tholt34
I am going to check these bolts tonight b/c my shifter has a lot of play and won't let me go into manual first so i figure it needs to be adjusted.
But my next question is, could it being out of adjustment tell the transmission to downshift into the wrong gear? What i mean is here lately when i pull up to a red light or even stop and put in park and go back into drive it acts like the truck won't downshift itself into 1st. It kinda feels in between gears and you can barely bump the throttle and you feel it lock in first and then the tranny shifts out fine. Just looking for any info here. thanks guys.
Tim
Old May 14, 2010 | 12:59 PM
V10inVT's Avatar
V10inVT
2001 F350 sloppy linkage
Same issue. Read this forum, ran outside and fixed it. Far better than when I bought it used last year. Thanks Mach1 you're my hero...
Old Jul 10, 2010 | 01:28 PM
fledis's Avatar
fledis
Same issue on a '03 Excursion. Was hoping it was going to be an easy fix, but when I checked the screws they were still in tight. Does anyone know how to adjust the actual cable? I tried to take it out of the bracket and tighten it, but I can't get it out. Any help would be greatly appreciated.
Old Jul 10, 2010 | 01:55 PM
beeguy's Avatar
beeguy
I had the same problem on my 99 PSD, sloppy shifter, my screws were tight on the end of the shifter tube, but the rubber bushings were shot. I replaced them and it works fine now . About 6 bucks at the dealer.
Old Jul 10, 2010 | 02:21 PM
fledis's Avatar
fledis
Mine will move right out of park to reverse or drive, but it won't shift back to the left. Once it gets to drive it won't go left to reverse or park, so I have to climb under and manually put it in park so it will start the next time. FUN!
Old Jul 11, 2010 | 03:54 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Won't it start in neutral?
Old Jul 11, 2010 | 08:32 AM
fledis's Avatar
fledis
Yes, it will start in N, but I put it in P because I need to put it into R eventually to back out of the driveway.
Old Jul 11, 2010 | 04:36 PM
  #28
RedBoat's Avatar
RedBoat
Rather Be Floatin
Thanks to everyone, I have a buddy with a f-150 that was only able to start his truck in neutral and had to jiggle the shifter to get his truck to start. I pointed him to this thread and in just a few minutes he found the bolts and tightened them and it fixed his problem!!
Old Sep 8, 2010 | 02:29 PM
  #29
trevstaff's Avatar
trevstaff
Guys, thanks for this information. This annoyance has been with me since I bought my truck. The fix took about 5 minutes.
Thanks!
Trevor
Old Sep 14, 2011 | 11:01 AM
  #30
SAlexander's Avatar
SAlexander
Just found this thread. I will try this fix tonight. How big are the bolts? Somebody posted that they found one on the floor and I think I may have found one a few months ago on the floor, but never figured out where it came from. My first thought was that it was from some interior panel. It was black and about 1 1/4" long by maybe 1/8" diameter. I do not remember what kind of head it had.
