390 or 391
Old Aug 27, 2007 | 11:12 AM
myfirstruck's Avatar
myfirstruck
390 or 391
I have been looking on this site with the seach tool and really have not found an answer to this question. This guy has an engine with the code d4te-1 on it. In a 67 f250 camper special truck he told me he thinks its the original engine. To me and with some of the research it looks like it could be a 391 I do not have the engine with me to look at any of it to verify. Is it original? Because if it is its a 390 but if not wouid I be better off trying to get a 390 to make a performance engine out of instead of this possible 391?
Old Aug 27, 2007 | 11:22 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
It can't be the original motor if it's got ANY part numbers with D4TE on it ...
Some of the casting numbers are the same across FT and FE lines... not many, but some - I'd suspect a block could easily be either/or.
Look at the exhaust manifolds - is there a crossover in the CENTER of the exhaust manifold? Is the timing cover cast-iron or aluminum? Where are the motor mounts?
Old Aug 27, 2007 | 12:33 PM
myfirstruck
The motor mounts are the same as a regular f100 pickup. Because its still in the truck.
WentzMetalWorks
24
Mar 9, 2025 08:36 PM
69blueford
32
Apr 13, 2017 10:12 AM
F600Logger
Large Truck
Jun 6, 2015 05:57 PM
giantfr0g
Feb 28, 2009 12:47 AM
1972 SportCustom
13
Jun 15, 2005 11:56 PM
