Fuel system upgrade questions
Old Aug 29, 2007 | 05:39 PM
  #31
Pest007's Avatar
Pest007
I just bought the banks intercooler pipes and silicone couplings, I bought or made everything else I needed and saved a bunch, and saved time by not making my own pipes, plus they look way better...
Old Aug 29, 2007 | 05:47 PM
  #32
powerstroked162's Avatar
powerstroked162
I would make my own pipes but I want maximum airflow with minimal turbulence and restriction. I have even thought about doin a 3.5" IC pipe and IC setup.
Cowboy Steve
Old Aug 29, 2007 | 05:53 PM
  #33
Pest007's Avatar
Pest007
well, if you make your own, I have 4pcs of 3" tubing prebent to 90deg
I just didn't feel like messing with welding, and fit, and cutting more, and looked cooler with them painted and the intake is what got me...
http://i195.photobucket.com/albums/z...e/DSC01448.jpg
Old Aug 29, 2007 | 05:59 PM
  #34
powerstroked162
Do I see a stock airbox????? Whens the Kwik filter goin in?
Cowboy Steve
Old Aug 29, 2007 | 06:03 PM
  #35
Pest007's Avatar
Pest007
I know, I know, where do you guys get your quick filter stuff, how much does it run??
Old Aug 29, 2007 | 06:09 PM
  #36
powerstroked162
go to napa and buy you a 6637 air filter and a band clamp. Should be around $60 out the door.
Cowboy Steve
Old Aug 29, 2007 | 06:11 PM
  #37
Pest007's Avatar
Pest007
isn't there some piece of pipe that you need too? that runs from that rubber intake tube to the filter itself
Old Aug 29, 2007 | 06:14 PM
  #38
powerstroked162
you can use roughly 6" of 4" exhaust tubing to connect the two but I have heard of others just sliding the tube over the filter inlet and clamping it together.
Cowboy Steve
Old Aug 30, 2007 | 07:40 AM
  #39
Neal 97 250's Avatar
Neal 97 250
I slid my tube over the filter on my EX. It was a tight fit but it went. I found it easier to remove the boot that way you can finesse it from the inside also. Then used factory clamp. I had to cut the rubber nipples off of the boot though.
BTW tell NAPA you are an AAA member and they can give you a discount on this item I think around $48.00.
ten.mile
May 16, 2020 04:34 PM
pbruckne
6.7L Power Stroke Diesel
17
Jan 5, 2020 07:45 AM
ernesteugene
Oct 28, 2017 12:48 PM
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
Oct 18, 2016 06:34 PM
-Snake-
Nov 6, 2012 05:33 PM
