average trans temp?
Old Aug 26, 2007 | 11:49 PM
Donny_D's Avatar
Donny_D
average trans temp?
was just wonderin whats average automatice trans temp... 99 f350 7.3 of course... am just curios as to what ya'll run cause i am lookin at gauges now and was wonderin how hot it should go up to cause the one im lookin at goes up to 250... hope it dont get much hatter than that... Donny D
Old Aug 26, 2007 | 11:57 PM
Tenn01PSD350's Avatar
Tenn01PSD350
That oughta do it. get into the 200 range and you better be pulling over before you are forced to. That may be a stop you won't drive away from.
Old Aug 27, 2007 | 12:04 AM
white Buffalo's Avatar
white Buffalo
That should be just fine. Normally tranny temps run @ 70 degrees over outside air temps. Towing will run hotter. If you hit 220 you want to pull over and let her cool down. After the tranny mods I haven't seen mine go over 190 while towing my 10,000 lb 5th wheel.
Regular tranny fluid starts to break down around the 225 range, if you tow alot synthetics is the way to go. Cost more but can handle the higher temps much better.
Old Aug 27, 2007 | 01:45 AM
kupaa's Avatar
kupaa
Average temp on mine is 150-160 w/no load
Old Aug 27, 2007 | 02:39 AM
k2vailkid's Avatar
k2vailkid
I've never seen over 180*. Pulling 8K over an 11K ft pass, and not taking it easy. 200* seems like an issue, to me. Bigger cooler? If towing a load is a regular thing for you...
Old Aug 27, 2007 | 06:48 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
200 is NOT an issue. If you get to 220F you want to find a safe place to stop and let the truck fast idle in park or nuetral. These transmissions are designed to go to 250F for a short time with NO damage.
Old Aug 27, 2007 | 09:05 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
The transmission might be able to withstand the 200 or 250* temps but the fluid can't. It begins to sheer and lose it's lubricating qualities and then trans wear starts. Check this out:
Old Aug 27, 2007 | 09:54 AM
Mark Kovalsky
The fluid can take the temps, too. That chart is for 1960's type fluids. It is useless for modern fluids.
Old Aug 27, 2007 | 10:09 AM
driximus's Avatar
driximus
I dont see any higher then 150-160 unloaded. sometimes 170-180 but that is on really hot days.
Old Aug 27, 2007 | 10:47 AM
Texas Outlaw
Not a liberal...
Wow, DieselSite must be stuck in the stone ages then. Good to know.
Old Aug 27, 2007 | 01:48 PM
Mark Kovalsky
DieselSite is trying to sell coolers and synthetic fluids. That chart is a good tool to do both. That doesn't make the chart right.
I've gone around and around with Bob. He doesn't believe me, either. He has a vested interest in having people believe that chart. I know it's wrong.
Old Aug 27, 2007 | 01:57 PM
Texas Outlaw
Not a liberal...
Yeah I have no doubt that it could be a marketing tool. I will take your word for it. I never see over 150 to 160* and that's in Houston heat so I know I am good. Appreciate your input.
Old Aug 27, 2007 | 02:03 PM
John311t's Avatar
John311t
mine average about 140 on my commute to work and back. If im in the city for a long time, ill hit 165.
Old Aug 27, 2007 | 07:33 PM
Tenn01PSD350
Just speaking for myself, I will not drive around with tranny temps above 200. Fortunately it is not an issue for me. If it becomes one, there will be some aux cooling.
Just because it may or may not be able to take it is not good enough reason for me when keeping it below 200 is not that hard. Especially since mine also goes through the radiator too. I don't want that heat soaking into the coolant either.
I would think the cooler, the better for longevity. And my tranny gauge redlines at 260*. just my 0.02. Of course I'm lucky I don't tow much heavier than the boat.
Old Aug 27, 2007 | 07:43 PM
kupaa's Avatar
kupaa
Is it better for the trans to run on the cooler side.I see only 160 max when unloaded,would it be better to run a real big cooler like 28,000k to get in the 130 -140 range.Thanks
