4r100 upgrade
Old Aug 26, 2007 | 07:48 PM
c00nhunterjoe's Avatar
c00nhunterjoe
4r100 upgrade
alot of people have been asking "why do i need the 4r100 foreward planetary?"
well whle looking for fluid today i came across my old one
Old Aug 26, 2007 | 08:01 PM
97REDPSD's Avatar
97REDPSD
Thats why I replace mine to. I also did dual bushing center support.
Old Aug 28, 2007 | 01:38 PM
Neal 97 250's Avatar
Neal 97 250
Makes a good paperweight though.
Old Aug 28, 2007 | 10:32 PM
IDMooseMan's Avatar
IDMooseMan
Joe,
You had the tranny shop install this upgrade? And the other stuff, too, right? Do tranny shops do this kinda stuff on a regular basis or did you take your tranny to "performance" tranny shop?
Old Aug 29, 2007 | 05:57 PM
c00nhunterjoe
i did mine myself, that borke a weeek after towing my buddy's highboy up the side of a mountain literaly
Old Aug 29, 2007 | 06:25 PM
powerstroked162's Avatar
powerstroked162
The SD planetarys are much stronger. I believe I have a forward SD pump and planetarys in my tranny now.
Cowboy Steve
Old Aug 29, 2007 | 10:43 PM
c00nhunterjoe
the 4r100 planetary is a 6 pinion forged steel unit, the one out of an e4od is a 4 pinion aluminum unit
Old Aug 29, 2007 | 11:01 PM
RocknXJ's Avatar
RocknXJ
I just did my tranny at a local tranny shop. I had an aluminum planetary that looked like the one in that picture....the splines were stripped out of it. My tranny guy said it was because the oil goes to the rear planet last, so if the fluid gets weak, low or if the pump wears, then the rear planet and clutches don't get lubed well enough. It was rebuilt with all steel six pinion planets, increased count on all the clutch packs, better valve body, shift kit, billet triple disc TQ, pump modifications, etc, etc. The internal parts to beef up the E40D are readily available and pretty much any tranny shop can and very likely has done them. Find a reputable shop, talk to the tranny guy and see how you feel about what he says, and go from there.
I have no problem with the high dollar popular brands of super stout trannies. But, for many of us that won't ever drag race or sled pull, or don't plan to build 400-500 HP motors, a well build tranny from a local shop will work perfectly for us.......for quite a bit less $$.
ragphoto
Feb 13, 2011 01:25 PM
brickie
Aug 1, 2010 10:44 PM
Izzy351
30
Jun 23, 2009 09:45 AM
i eat hybrids
Oct 25, 2008 05:15 PM
c00nhunterjoe
Oct 13, 2008 09:49 AM
