air suspension
Old Aug 26, 2007 | 07:36 PM
ericnj75's Avatar
ericnj75
air suspension
how can u tell if u have air suspenion on a 99 expedition xlt
Old Aug 27, 2007 | 07:08 AM
BroncoScott's Avatar
BroncoScott
crawl under the back, if you have coil springs on the rear end then you don't.
Old Aug 28, 2007 | 10:42 AM
98EB-Expedition's Avatar
98EB-Expedition
That and if you don't hear a compressor kick on shortly after starting it up you don't have it. Every Expy with the Air suspension I have been in is quite noisy when you first start it up as you hear the compressor come on.
I got rid of mine and converted to springs when I started to have problems with it specifically for me it was the drivers front air shock/strut.
Old Aug 28, 2007 | 01:48 PM
Fat Man's Avatar
Fat Man
This is interesting, I've got an '01 with air suspension and I can't hear the compressor at all when I start up. I had a problem with my suspension this past weekend and I couldn't tell if it was the compressor because nothing sounded different. I'm going to have to pop the hood and have someone else start the truck so I can figure out what I'm listening for...
Old Aug 28, 2007 | 03:11 PM
SMIGGS's Avatar
SMIGGS
My compressor kicks in after I take it out of park, not when the truck has just been started. You should be able to see the compressor underneath your windshield washer resevior. ( sp? )
Old Aug 28, 2007 | 04:25 PM
Fat Man's Avatar
Fat Man
Ya, I can see it there - and at this point I know it's working since I just got it back from the shop. I just haven't noticed it working, I'm usually good at picking out the sounds, but I haven't heard this one?? I'll figure it out, I'm sure it's good to know...
Old Aug 28, 2007 | 09:32 PM
Dre82s's Avatar
Dre82s
Where can I get replacement airbags, airline and fittings? I have a problem with passenger rear on mine not sure what gave out but I hear a leak and check suspension light keeps coming on after a while and rear drops to the axles
Old Aug 28, 2007 | 09:46 PM
Mark62's Avatar
Mark62
I did a google search...here are 3...
http://www.strutmasters.com/catalog.php?cat=52
http://www.suncoreindustries.com/fordexp.asp
http://www.suspension-alternatives.c...on-System.html
Old Aug 28, 2007 | 09:53 PM
Fat Man's Avatar
Fat Man
One of the other threads said that Strutmaster and Suspension-Alternatives was the same place, but that Susp-Alt was A LOT cheaper. I'm sure you can compair them yourself, but I thought I'd mention it...
Old Aug 29, 2007 | 08:01 AM
Rockefeller.hayag's Avatar
Rockefeller.hayag
Check air line union under/near brake master cylinder
CHeck the air line connection that is under brake master cylinder. May have popped off/disconnected. Happened to me; reconnected and moving right along. I ordered the SPider Jr. to replace the air line union. Will connect when it arrives.
Old Sep 1, 2007 | 08:59 PM
marinazaz's Avatar
marinazaz
http://www.arnottindustries.com/part...id3_gid39.html
This is where I purchased mine for my 98 Expy. Put them in myself and they are awesome, no problems!
Old Sep 4, 2007 | 12:09 PM
JKTX21's Avatar
JKTX21
I just put springs on mine finally. There was a leak in the line and the compressor burned up.
I really like the load leveling suspension, but I felt like I needed to replace all the components with as many miles as my truck has, and the springs will do the trick for now!
Old Sep 5, 2007 | 08:50 PM
TexFinn's Avatar
TexFinn
Did the same thing on mine a few weeks ago and I was kicking myself for not doing it earlier.
200 bucks well spent. Installation took only a couple of hours and the ride is at least as good as before, if not even better.
The only regret I have is that I didn't change the rear shocks while I was under there. Oh well...
RUBICON
2015 + Expedition & Navigator
Jun 24, 2017 11:18 AM
ap4u06
Mar 18, 2011 06:06 PM
DRRXR
31
Mar 23, 2010 10:16 PM
rockher_man
15
Mar 5, 2009 08:48 AM
fordguy101
Aerostar
15
May 14, 2005 08:05 PM
