4 X 4 transfer case
Old Aug 26, 2007 | 12:46 PM
katiesdad7's Avatar
katiesdad7
4 X 4 transfer case
Does anyone know if you can put the transfer case in neutral? I want to tow it flat behing an RV.
Thanks,
Old Aug 26, 2007 | 01:51 PM
ZBeeble's Avatar
ZBeeble
usually the 'X tows the RV, not the other way around. Heck, if you owned an X, why would you get a powered RV?
For that matter, you might be better off milage-wise to tow a flatbed with the X on it, should you insist on towing it...
Old Aug 26, 2007 | 01:54 PM
Monsta's Avatar
Monsta
Sit. Stay.
I don't know if the auto X-fer case can go into neutral. Doesn't matter, you'd have to remove the rear driveshaft to flat tow it anyway.
Old Aug 26, 2007 | 01:57 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
No, no neutral on the transfer case. Unless you have the stick on the floor, which I don't think is possible with the X
You'll have to disconnect the rear driveshaft. Not too hard, but the bolts are pretty tiny and the heads strip easily. Get an extra set of bolts "just in case".
Old Aug 27, 2007 | 03:58 PM
katiesdad7's Avatar
katiesdad7
4x4 transfer case
Sort of what I thought. I love my 05 Ex with the 6.0 and plan on keeping it till the wheels fall off. I only have 12 K on it. Changed the oil on it twice so far. The dealer charges $59 for the lube, oil and filter with a coupon.
This is my 2nd Ex. My first was an 02 2WD with the 5.4 gas. My 05 EB has more stuff than my 02 Limited.
Old Aug 27, 2007 | 04:17 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
I get my oil changes for free in my X at the delarship
Nick
Old Aug 28, 2007 | 07:19 PM
katiesdad7's Avatar
katiesdad7
Nick
I see you tow 13K. I thought the EX can only tow 11K?
Old Aug 28, 2007 | 07:45 PM
vettdvr's Avatar
vettdvr
If the there is no rear pump in the transmission (there isn't) you run the risk of transmission damage by continuously turning the drive shaft by towing the Ex any distance, not to mention the tx case.
The 49 caddilac had front and rear pump you could actually push start the car because the rear pump would turn the tranny and engine to allow the engine to start. If I remember correct dual Hydromatics were used in the Sherman tank,, tough tranny's.
But the Ex.. na,, no rear pump,, can't use it in a tank either. Jim
smittys5xs
1978 - 1996 Big Bronco
Apr 22, 2015 09:44 AM
puffere
Mar 22, 2015 12:13 PM
Andy Sullivan
Feb 15, 2014 04:52 PM
RBlanton
Jan 13, 2014 02:19 PM
DarrellJ
Dec 26, 2009 02:11 PM
