1975 transfer case
Old Mar 22, 2015 | 11:11 AM
puffere's Avatar
puffere
1975 transfer case
Some years back I owned a 1775 F150 4x4 with a transfer case that had 4-low 4-hi and also 2-low and 2-hi ...what was that transfer case called
Old Mar 22, 2015 | 12:13 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
That shift pattern sounds odd, but close to a (New Process) NP-205. No 2-Low unless you had it twin sticked?
Other transfer case to have is a NP-203 full time 4x4 transfer case. With NO lock in/out hubs on the front axle.
In the pic below a NP-203 is on L/H side and NP-205 is on R/H side.
"The Ford Dana 20 transfer case is gear driven with a cast iron case. It was used in early Broncos from 1966 until 1977 and it was used in some Ford pickups. It is drivers drop and it was available with a couple different low range ratios." ?
truckmonger1
Mar 26, 2007 09:19 PM
cryptonik420
Dec 3, 2002 12:57 PM
Geffrey Travis
Oct 15, 1999 08:56 AM
