uplifter switch wiring diagram
The pass-thru wires and the blunt cut upfitter wires are all in the same general area. Yes, if you want to use them, you have to make the splice yourself.
You should be good with 10A using those wires. I wouldn't go much more than that. They look like only 16ga wires to me.
Welcome to FTE!!!
I've thought add maybe 3 or 2 pieces 10 watts mini led lights to back.. My only problem which I've wondered its do i need to add relays between upfitter switches power cable and my worklights? Or it is just enought to just connect up fitter switches power cable to to worklight and bolt ground wire to some good place in truck..?
And do u guys have any good tips how to wire cables from the cab to the rear of truck?..
http://www.lakeudenkone.fi/tuotteet.html?id=57/318 this model lights im going to add, helps a lot when dark..
i apologize my bad english.. im finnish guy, and super dutys are very uncommon in here Finland, so have to ask u guys.. Thx for answers!
Those draw 3/4 amp each, if I'm reading that page correctly. You could wire a bunch of those to any of the upfitters, without needing a relay. Just run a power wire from a switch output, and ground each lamp. Done. Easiest would be to use one of the pass-thru firewall wires.
Työvalo led 10W flood | Lakeuden kone ja maataloustarvike Ky this model lights im going to add, helps a lot when dark..
How do I remove the switches from the dash?
I ran a test light and the 4 wires (red white blue and black) have no power in the engine compartment.
That photo comes from this page below, which might help orient you:
Installing Upfitter Switches - Ford 2005-2007 Superduty
The colors are not the same as the upfitters, because they are not necessarily intended for use with upfitters. And if fact, the pass-through wires are not large enough for upfitter #1 or #2. So be careful and don't overload them. Use relays for your lights, or else don't use the pass-through wires. You could run 4 x 50W (17 amps total) lights directly off of a 30A upfitter, but NOT if you use the pass-through wires.
