Fan removal tool
Old 08-25-2007, 03:33 PM
Ford79's Avatar
Ford79
Ford79 is offline
Fan removal tool
Is there such a thing? I need to replace the fan on my truck and I'm pretty sure there is, but want to know what to ask for when I go to the parts store later.
Old 08-25-2007, 03:48 PM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
yes there is..but for the life of me i cant remember what it is called...i also found one on line a while back..but i cant find it now.sorry...wish i could help you more.
Old 08-25-2007, 05:32 PM
Benny2002's Avatar
Benny2002
Benny2002 is offline
Autozone hast them...Fan clutch puller or removal tool is what its called if i remember right
Old 08-25-2007, 06:22 PM
Ford79's Avatar
Ford79
Ford79 is offline
My local parts store doesn't have the correct size. They don't even have tools for rent/loan anymore
Old 08-25-2007, 06:32 PM
sgrol's Avatar
sgrol
sgrol is offline
for the big fan to water pump nut - a big crescent and hammer. Tap tap and it will unscrew by hand.
Old 08-26-2007, 10:46 AM
Ford79's Avatar
Ford79
Ford79 is offline
I found out the nut is 45mm, I don't believe I have a crescent that big. I'll be checking a few places tomorrow after work.
Old 08-26-2007, 10:47 AM
ron's power stroke
thanks for the tip
Old 08-26-2007, 11:15 AM
Rich in CO's Avatar
Rich in CO
Rich in CO is offline
I just used a big ol pipe wrench and a big C clamp to hold the pulley in place while removing the nut.
Old 08-26-2007, 11:54 AM
wlihntr's Avatar
wlihntr
wlihntr is offline
yep, i do the same thing
Old 08-26-2007, 12:35 PM
Action4478's Avatar
Action4478
Action4478 is offline
If you use a drift & a hammer , just tap on the outer most part of the fan nut & it should come right loose ,(Emphasis on tap...)
Old 08-26-2007, 03:04 PM
sgrol's Avatar
sgrol
sgrol is offline
I found a large crescent (24") at Harbor Freight or Discount Tools for a pretty cheap price a while back.
Old 08-27-2007, 11:26 AM
nodakford's Avatar
nodakford
nodakford is offline
The fan nut should be a 1 7/8 nut. What I did is removed a couple bolts holding the pully on. I took a piece a steel bar stock, about a 1/4 in thick, 1" wide and about 30 " long and drilled a hole in it about 3" from the end. I then used the bolt from the waterpump pulley and screwed the bar stock on the pulley. It ends up working like a spanner wrench,as you rotate the fan nut the bar stock will jam up and hold the pulley and allow the nut to break free. I did not marr anything up doing it this way. I also had to use a dead blow hammer striking the wrench to get it to break free. They do make a fan nut tool that holds the pulley by fitting over the bolt heads. The one I just saw said for the Ford 7.3.
Old 08-28-2007, 12:26 AM
themox's Avatar
themox
themox is offline
I use a air hammer with a long bit, but you have to be very careful not to let it jump off the nut. It can do more damage to other parts. Just tap it once, and spin it off by hand. The drift, and hammer, that Action4478 said is probably a safer idea. After you break it loose, it just spins off by hand. You would be very lucky to find a crescent wrench thin enough to be usefull for removing the fan clutch. It's pretty tight in there. If I remember right, the correct tool was very thin, and had a half inch drive hole in it for a ratchet to fit. I dont remember, .......... I will re post when I sober up, and my memory comes back. I hope I can remember posting this at all.
Old 08-28-2007, 03:09 AM
AustinS's Avatar
AustinS
AustinS is offline
This link will give you the info you're looking for:
http://www.otctools.com/products/200...38AutoSpec.pdf
They are spendy at around $150 for the set of two. I'm lucky enough to have a machinist two houses down who owns a 7.3L. He's made all kinds of 7.3L specialty tools that I am fortunate enough to borrow when needed.
I too used the method described by wlihntr & Rich in CO before my neighbor made his set, and it works just fine.
Here's the pic and #'s for the two wrenches Ford lists for this repair:
[IMG][/IMG]
Good luck and I hope that helps,
Austin
Old 09-02-2007, 02:43 PM
Ford79's Avatar
Ford79
Ford79 is offline
I finally got time to replace the fan. It turns out the nut is not 45mm. I ended up buying a 1 7/8 wrench from Northern Tool and it fits good, just slightly larger than the nut, but not enough to worry about rounding it off.
I started by removing the belt, then siphoning out the coolant in the reservoir and removing the 3 bolts securing it(8mm) Once the bolts are removed, remove the small hose on the right side and rotate the reservoir 90 degrees CCW to get it out of the way. Then remove the upper hose from the radiator and tie it out of the way, then the 2 bolts securing the fan shroud(8mm) can come out. Next, take a 6" or larger c clamp and clamp it on the water pump pulley to hold it in place while you break the large fan clutch nut loose. After the nut is broke loose, you should be able to rotate the whole fan/clutch assembly by hand to remove it from the water pump.After the fan comes off, remove it and the shroud at the same time.
steve340
05-10-2014 07:20 PM
dongc1
08-08-2012 07:25 AM
cutlass
07-15-2012 11:16 AM
carrfamilynj
22
11-09-2006 05:37 PM
ClemsonLightning
06-22-2004 08:30 PM
Quick Reply: Fan removal tool
