Did they all come with the sterling axles? How can I find out if I have one? Sorry about the dumb questions but I am going to try and change my fluid this week and I might as well put on a new cover if it will fit mine. I am going to use royal purple fluids, is this alright for our trucks, what weight of oil?
yes your truck has a sterling so the cover will fit. RP fluid is good. Its what I run. Can't remember what weight. its not what Ford recommends but it works great.
Ok my diff is 12 bolt and it looks like it should fit. It looks like the one in the pic above. I looked on the door and the axle code says D5. Is this a posi or limited slip? How much fluid does it hold with the new cover?
your diff should be a 4.10 with limited slip if I remember correctly. it will hold between 3 and 4 quarts. the new cover doesn't hold any more oil but I think the capacity is like 3.5 quarts or close to
