Modular V10 (6.8l)
v10 engine problem
Old Jan 3, 2002 | 11:19 PM
yz429's Avatar
yz429
v10 engine problem
I have a 1999 F250 4x4 XLT reg cab v10. I bought it new in Jan '99. It now has 19k miles. I have made no changes to the truck other than a leveling kit for the suspension. I have had no major problems, but I get a unsmooth idle at times. This seems to happen only briefly. (like slightly skipping a beat, not a hard miss) Has anyone else had this problem or know what it could be. It doesn't seem to affect overall performance, but I don't like the fludder. Time has lapsed and warranty is out.
Old Jan 4, 2002 | 08:15 AM
NoMo's Avatar
NoMo
v10 engine problem
Do you have an EGR system? If so, it may be causing the truck to starve for fuel in an effort to lower emissions. Also, there is a history of the Idle Air Control (IAC) valve failing on V10s. Maybe yours is almost bad? Weak or dirty injectors... so many causes!
I had a '93 F150 that did as you describe. It would almost die at idle sometimes though. Anyway, I took it in to get it "fixed". Whatever they did to alter the idle made the truck lose some overall power. Looking back, I wish I'd just left it alone.
Old Jan 4, 2002 | 01:37 PM
RollingStone's Avatar
RollingStone
v10 engine problem
Oh hi,
With out any knowledge on this engine (yet), if it has a throttle position sensor it could be bad. I had this problem on an Explorer. It was a simple replacement.
Old Jan 4, 2002 | 03:14 PM
Monsta's Avatar
Monsta
Sit. Stay.
v10 engine problem
Mine does it too. Not real noticeable unless I'm trying to listen to it. I'm gonna have the dealer look at that, as well as a list of things I have, come Monday. I'll be happy to post his answer.
Old Jan 4, 2002 | 08:47 PM
nothingbutford's Avatar
nothingbutford
v10 engine problem
My father's 98 Club Wagon with the V10 does the same thing after idling for about 20 minutes. It is a slight vibration and sound change. It corrects itself in about 10 seconds. Reving the engine up also corrects it. Benjamin
Old Jan 5, 2002 | 03:41 PM
3992824's Avatar
3992824
v10 engine problem
Could what's being described be the infamous 'flutter' exhaust problem that some of these V10's have?
Old Jan 6, 2002 | 10:09 PM
Monsta's Avatar
Monsta
Sit. Stay.
v10 engine problem
Old Jan 6, 2002 | 11:50 PM
V10gunner's Avatar
V10gunner
v10 engine problem
"Flutter" occurs under acceleration, not at idle, and manifests itself as a noise, not a change in performance of the engine.:-(
-V10gunner
'00 SD F250 Super Cab XLT, 4X2, 142"WB, 6.8L V10, 4R100, 4.30LS, Camper Package, Dark Toreador Red over Silver, Snugtop Xtra Vision Cab-high shell
billy37380
Modular V10 (6.8l)
May 10, 2016 02:16 PM
buddharacing
Modular V10 (6.8l)
Jan 21, 2016 04:15 PM
adr3naline
Jan 10, 2016 04:07 PM
RWG78
Modular V10 (6.8l)
75
Feb 13, 2012 02:42 PM
