V10 fails to start
V10 fails to start
Hey guys here's the problem
2000 F-250 V10 automatic
It turns over but wont start. Every so often it will fire up and run just fine no stalling. once started it will restart fine for a few times. It doesn't throw a check engine light and it wont get a connect to a code reader. I had a throttle position sensor self test fail the first time it did this and replaced the sensor with no results. Starting fluid has not worked yet. Seems to have no spark. I'm thinking my pcm might be on the way out.
