I have 4in pipe from turbo to tail with a crome 4in tip. I'm thinking of changing over to a 5in tip just for the cool looks of it. I know there will be no peformance gain, but will there be a sound difference from a 4in to a 5in tip.
I installed the stainless mbrp 4 in turbo back last spring. I also bought the polished 5 inch stainless tip. It goes on tight so i used a block of wood and a hammer to get it on up to the clamp. It looks real nice. I dont think it will change any of the sound because it is at the very end. But it sure adds the sparkle to the end of the pipe. and it doesent rust or anything its abot 50 bucks i think. jeff
I run a 4" to 6" MBRP tip in the summer, and swap to a piece of swelled 4" exhaust pipe for the winter, as the stuff they put on the roads in winter around here has started to rust my truck. There is a definite tone difference, both are unique, but it sounds the best with the 6"!!!
Haha, your trucks rusting out from the salt on the roads in WA? Man, you must be washin your truck with that salt solution as well, lol. Never seen a WA truck rust out from road salt in WA, now you got back east like NY and you'll se new '04 and '05's rusted through.
I've been workin on a gallery today, so its comin no worries.
I'll give ya a mod list;
BDP stage 2's
BDP D66
Dp-Tuner 6pos with custom BDP tuning
BDP 140v IDM
5" Diamond eye exhaust
BDP 3.5" DP
Ts Powerfool No2 system
Rabbit Mfg. ported fuel bowl assembly
Rabbit Mfg. custom fpr (90+psi)
Rabbit Mfg. CCV mod
Rabbit Mfg. porting
SD HPOP
Tymar Intake
All this is ran through an ATS triple-lok convertor and billet input shaft, transgo Dash-2 tugger valve body, ATS pan, tru-cool max load cooler.
Dude, you have my attention. I am always curious how folks achieve big #s on these powerplants.
There seems to be 2 kinds of folks here, those that look and try to creep up on the big HP stuff, (me) and those that just BAM appear with all the goodies. I could never be one of those until after my divorce and the kid was done with college. I think I will remain a creeper.
