Sponsored by: Real Truck
a/c trouble
Old Sep 7, 2007 | 10:19 PM
F250tuff's Avatar
F250tuff
If it was two cans low, you have a leak somewhere. You can keep adding freon to it as needed, but eventually it will get enough moisture in there that it won't cool anymore. If you can afford to find the leak and fix it now, you will save money down the road. Moisture in the a/c oil can kill the compressor.
Old Sep 10, 2007 | 07:39 AM
tpepper's Avatar
tpepper
I'll get to looking. Thanks again, tpepper
Old Sep 10, 2007 | 08:08 AM
RagdollRacer's Avatar
RagdollRacer
I had the same problem last week. I put freon in and it worked for a while but failed again. I found a leak at the upper hose clamp. A new hose assembly from dealer was $159.00. I had just the hose replaced at a local AC place here in town in about an hour for $40.00. They cut off the metal above the clamp and welded in a completely new hose of better quality than original.
jeffrey5679
May 8, 2013 09:29 AM
racerx6466
1997 - 2003 F150
Jul 29, 2009 08:09 PM
oshoguno
Aug 21, 2005 10:04 PM
YOMAN
2004 - 2008 F150
Apr 20, 2005 04:27 PM
