Windshield seal repair help
Old Aug 22, 2007 | 11:26 PM
MineralStang's Avatar
MineralStang
Hello everyone! I need some help with my '76 F250. The windshield seal is leaking onto the drivers side dash and I need to fix it. On the outside, the rubber seal is well worn and cracked so I was just going to replace the seal on the windshield. I was looking at LCM truck and you can buy the whole rubber seal that goes around the windshield. Is this all I need? Or is there something else I need as well to fix the seal? It looks like there is only one seal, not an inside and outside seal, is that correct? Thank you for your help! BTW...can I do this myself?
Nate
Old Aug 22, 2007 | 11:35 PM
Mil1ion's Avatar
Mil1ion
Buy it from here instead.
http://blueovaltruckparts.com/catalo...?cPath=242_248
I'm pretty sure they get theirs from these people.
http://www.metrommp.com/
http://www.dannoenterprises.com/wtruck.htm#FordFS
Old Aug 23, 2007 | 12:38 AM
oldjag's Avatar
oldjag
I just did the windshield seal on my 1977 F250. Got one from NPD/Dennis Carpenter. Two types of seal are available, I used the single piece type, but a two part type that uses an decorative insert can also be had. I really takes two people to do the job, one inside one outside. The Ford shop manual has a good procedure. One area that can leak is where the roof meets the top of the window frame - I've been told by an old Ford assembly line guy that often this area was a problem and they often leaked from new. On mine the seam weld needed a little grinding to prevent a potential leak path under the windshield seal. You stand a 50/50 chance of breaking the old windshield if/when you try and reinstall it - old glass is more brittle. Use a razor around the outside of the old seal to cut it. The windshield will then pop right out. Use lots of lube when installing the new seal/windshield - I used clear electricians wire pulling compound I had on hand that I got from Home Depot. Dishwashing liquid, KY, etc. may also work....
Old Aug 23, 2007 | 10:23 AM
MineralStang
Thanks for the info. It's leaking above the steering wheel on the upper part of the glass. At least thats where the water is dripping from. I just need to replace the window seal and the door seals before winter and wanted to save some money. This is not a show truck and its used in the winter primarily. I'm thinking about trying it myself for $45 for the seal and my time instead of $120+ for some auto glass place to do it. The windshield is not cracked and is in great shape so it doesn't need to be replaced. Hmm...
Old Aug 23, 2007 | 11:51 AM
HareBall's Avatar
HareBall
But if the auto glass place breaks it they bought it.
Old Aug 23, 2007 | 01:48 PM
Mil1ion's Avatar
Mil1ion
Plus, you can hire an installer for "after work hours" to install it for $25.00 or a case of beer sometimes and YOU still risk the breakage problem.
I got my windshield and rear window (which I supplied) on my mustang done by an installer for $50.00 cash.
IMO, Pay the installer and don't look back.
It is well worth the cost.
Old Aug 23, 2007 | 06:37 PM
Action4478's Avatar
Action4478
It is a very simple job, I have done it many times, On my truck I did it by myself.....
52' fordnut
Nov 15, 2014 10:25 AM
hdman6
May 22, 2012 10:17 AM
iwanaflattie
Nov 10, 2010 04:53 PM
Metdawg44
Mar 5, 2009 10:30 AM
dorkpunch
Nov 11, 2005 05:28 AM
