Modular V10 (6.8l)
Miss
Old Aug 22, 2007 | 09:09 PM
mikegp1's Avatar
mikegp1
Miss
Today my 99 F350 with the 6.8 starting missing. I check the codes and got a P0300 and I checked the fuel pressure and it was real low. So I changed the filter and pump. Its not much better. Between 1,000 and 2,000 rpms it miss;s real bad and I dont know what to look at next.
Old Aug 23, 2007 | 12:58 AM
triton's best's Avatar
triton's best
maybe injectors?
Old Aug 23, 2007 | 02:12 PM
v10lampert's Avatar
v10lampert
maybe you have a cloged fuel line?
Old Aug 23, 2007 | 04:26 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Is the pressure still low?
Check the fuel pressure regulator - maybe something got stuck in it.
What I do is, hookup the pressure gauge, start the engine, and it should be 28-30lbs.
Disconnect the vacuum hose to the regulator, and it should jump to 38-40-42 or so.
If the pressure checks out, clean the MAF ... check for vacuum leaks, etc.
Report back!
krewat's Avatar
krewat
BTW, if it was the injectors, he'd get a solid miss on the bad injector(s) instead of the P0300 which is (I think) random misfire.
Old Aug 23, 2007 | 08:21 PM
jmannz25's Avatar
jmannz25
i have a 99 v10 with an exhaust and diablosport predator tuner and when the tuners on it misses right off idle... wat do i have to adjust
Raider1kilo
Feb 13, 2014 10:55 AM
mike L
Jan 9, 2013 09:49 PM
t1darian
Nov 3, 2011 11:33 PM
hotrod99
Mar 26, 2007 12:28 PM
xls
Aug 22, 2003 10:41 PM
