Resetting the Check Engine Light.
Old Feb 1, 2014 | 01:31 PM
Raider1kilo's Avatar
Raider1kilo
My 1998 Explorer with 120,000 mile on it. The check light just came on. I have had several auto part stores plug in the scan tool and there were no error codes
I'm looking for the reset button location. I am also wondering should there be something missed by the scan tools, will the light activate should there be a real problem.
Thanks,
Raider1kilo
Old Feb 2, 2014 | 01:06 AM
87 XLT's Avatar
87 XLT
There isn't any reset button. See if your cigarrete lighter is working. If it isn't,replace the fuse & see if you can then pull the codes.
Old Feb 2, 2014 | 09:37 AM
shorod's Avatar
shorod
Were the stores having difficulty getting the scan tool to connect, or were the tools reporting that there are no diagnostic codes after a successful scan?
As mentioned above, there is no generic reset button. If the system causing the Check Engine Light (CEL) to come on stops reporting an issue, the light will go out after several drive cycles with no instance of the issue. But the CEL will not illuminate for no reason. The scan tools used by just about every parts store will only read powertrain diagnostic codes. There can be non-powertrain codes that cause the CEL to illuminate but cannot be accessed by a standard scan tool. For those, you'll need to find a professional scan tool.
-Rod
Old Feb 2, 2014 | 11:58 AM
Raider1kilo
Resetting the CEL
I took the Explorer to a shop and was told there is are codes,.
P1309 Misfire monitor and a P0340, Camshaft Position Sensor A Circuit
Bank 1 or Single Sensor.
Is this a major job, I am good with auto repairs, but is this something I should take to a shop or dealer ?
Thanks,
Raider1kilo
Old Feb 2, 2014 | 08:46 PM
steve(ill)'s Avatar
steve(ill)
Old Feb 2, 2014 | 10:06 PM
Raider1kilo
Cam Shaft sensor
Thanks for the video. I guess I'm going to the Ford shop and pucker my a**
Thanks , Raider1kilo
Old Feb 9, 2014 | 02:25 PM
Graygeorge's Avatar
Graygeorge
If you have SOHC 4.0, remove sensor at the front of left valve cover, clean off the sensor and see if that makes a change. Mine was dirty, oil, etc. and showing a CEL, clean it, then no CEL.
Old Feb 10, 2014 | 04:44 AM
oneowner83's Avatar
oneowner83
What type of sensor is that?
Old Feb 10, 2014 | 11:37 AM
Graygeorge's Avatar
Graygeorge
Camshaft Position Sensor | 1998 Ford Explorer 4WD 6 Cylinders E 4.0L EFI SOHC | AutoZone.com
Old Feb 13, 2014 | 10:55 AM
Raider1kilo
Thanks to all that replied. I wound up taking it to a local shop and the owner has the same Explorer. Turned there were two faulty sensors, With the oil change and tire rotation the bill was $199.90. Plus he washed all the salt, dirt and cleaned the interior.
I think I'll be using him again.
mrsvegan
Oct 11, 2013 08:10 PM
mattyk6_bdr
1997 - 2003 F150
Jul 31, 2007 01:59 PM
bubbies24
Mar 16, 2007 10:03 AM
manasota
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 13, 2005 08:47 AM
CMMerscher
1997 - 2003 F150
Nov 11, 2003 09:09 PM
