Modular V10 (6.8l)
K & N Airfilter !!!
Old Mar 23, 2002 | 08:27 AM
  #31
Twinbulls's Avatar
Twinbulls
K & N Airfilter !!!
monsta said..>In my humble opinion, unless you plan on changing the
>exhaust too, don't expect great things. You may want to look
>at the thread up in the Super Duty forum entitled "Simple
>Air box Mod". I think it is a cheaper alternative to the K&N
>FPIK. Neither will give you true cold air induction just as
>neither ALONE will give you any noticeable increase in
>anything. 'Cept maybe intake howl!! <No offense to
>those who have "experienced" positive effects.>
Monsta I added both the K&N FIPK and the Poweraid spacer (at the same time)and my throttle response was GREAT it reved up faster and it added A powerband (sweet spot)With factory exhaust.
As for the air box mod I tried it and it did do a little but nothing like the FIPK it lets so much more air in.With the larger cone filter it must let more in.
>If you change the intake characteristics you MUST change the
>exhaust characteristics. Doin' one without the other is like
>brushing your teeth without toothpaste. Kinda works but not
>really.
Thats why I removed the muffler.(this also helped out a lot)Headers will be next.
>I can see these spacers giving a slight advantage if our
>trucks had a big ole carb sitting on top. But they don't.
>How moving the throttle body assy. 2" away makes any
>difference is beyond me.
I thought the same as you ,As I am always looking for added power I like to try for myself and it was only $98 bucks I figured what the heck. Glade I did try it..and if I didnt like it I could always send it back or sell it on E-bay.
>On a carb it could effectively allow more time/help increase
>air velocity/swirl/whatever for the fuel to atomize.
>Certainly not the case with our fuel injected engines.
I also think this way,One benifit is the spacer does take up the slack in the throttle cable and as I figure it must help spin more air in to the intake or speed it up or even compress it alittle? but again for me it helped and my thoughts are I need all the ponies that the v-10 has.So I am willing to try just about anything.As we all know the V-10 is in its infantsey (SP) And we all must find out what works and what doesn't.I plan on trying all that I can (with out wife knowing of course)
Just to let you all know I live in South FL at sea leavel (or just above)if that matters.Because I did notice that my truck runs so much better when its 45 degrees out and I was in Texas.Recorded a record MPGs at 16 MPGs.(that ways a great 2 weeks)
Well I hope this helps In my humble opinion
twinbulls
No Flames intended
Old Mar 23, 2002 | 11:31 AM
  #32
NoMo's Avatar
NoMo
K & N Airfilter !!!
I think the key thing that gets overlooked is that performance is comprised of many things... one of which is throttle response. Opening the airbox may not give huge power increases (or any power increase at all), but throttle response is almost universally better when the ECU isn't having to wait on air before adding fuel.
Old Mar 24, 2002 | 09:27 PM
  #33
SVO's Avatar
SVO
K & N Airfilter !!!
srpservices
Sep 12, 2013 09:03 AM
n001pa
3.0L V6
Jan 8, 2006 06:48 PM
ford390gashog
General Automotive Discussion
102
May 24, 2004 07:45 PM
threetago
2004 - 2008 F150
Apr 25, 2004 12:18 PM
fire23
Feb 29, 2000 09:00 AM
