Modular V10 (6.8l)
Hey Abendx
Old Apr 4, 2002 | 01:19 AM
chadrock's Avatar
chadrock
Hey Abendx
I have a few questions for you...
1) So you've had that chip in for about a week now. What do you think (power, shifting, mpgs)?
2) I have noticed that with my swampers, the front end of my truck makes a vibrating sound slowing down or speeding up between 15-25 mph(sounds like its the heat shields behind the roters vibrating). I think its because of the way the swamper tread is. Does your truck so that as well?
3) Is your steering wheel kind of turned to one side so it isn't straight since your trucks been lifted? Do you know how to fix it if it is? I know that the lift changed the angles on some parts of the truck.
Let me know. Thanks :-X11
Old Apr 11, 2002 | 08:25 AM
RockyMountain250's Avatar
RockyMountain250
Hey Abendx
Well I can't comment on the chip but the problem with the stearing wheel is that your truck needs a alignment after lifting it. The lift will change the distance from the pitman arm to the axel and in order for the linkage to reach the arm has to turn to the right which in turn moves the stearing wheel. Now the hard part is finding a alignment show that can fit your truck on the rack. I had to search all over for one, the main problem is the length of the trucks and then you throw in the bigger tires and it gets even harder. I know some places will do them if you put the stock tires and wheels back on but I was lucky and found one that would do it with my 35's. Talk to your local 4x4 shop they should know a place tha can do it. Good luck....
Old Apr 11, 2002 | 09:00 AM
Quikirk's Avatar
Quikirk
Hey Abendx
Old Apr 11, 2002 | 01:01 PM
abendx's Avatar
abendx
Hey Abendx
ummm... wish i could tell you..... i have had it out for the last week..... sent it back to the dealer for reprogramming since my speedo still isn't calabrated.... this will put me back to squeare one... so i will have to let you know at a later date. sorry man!
yes... speed has to do with the ammount of vibration and sound... mine gets really loud and vibrates really hard around 10mph... especially when slowing down.... it all has to to with teh tread width.... didn't you run swampers before? i have run lots of bfg m/t's in teh past and they do the same thing... although not as wildly since they are not as aggressive. i wonder how cool boggers would sound????
the steering wheel can be re-aligned by adjusting the track bar. there are a couple of nuts on it and if you lossen them up u can make the adjustments to get your steering wheel straight.
not entirely true.....
yes an alignment is needed after a lift to keep your truck tracking a straight line correctly, but not to fix a mis-aligned steering wheel.
Old Apr 11, 2002 | 02:13 PM
RockyMountain250
Hey Abendx
Well yes you are correct that the alignment alone will not fix the steering wheel but they do adjust the rod the connects the pitman arm to the steering linkage to straighten the wheel. I am pretty sure that this is what you are refering to and it is different from the track bar which keeps the axel centered under the truck and is not adjustable.
This is why lift kits come with the new track bar bracket to keep the bar and the connecting rod for the steering parrallel. There are adjustable track bars made for jeeps and such but I have never seen one for a superduty.
If I am wrong I apologize and hope that I didn't step on your toes .....
Old Apr 11, 2002 | 04:23 PM
abendx's Avatar
abendx
Hey Abendx
no toe stepping... and you are right... i guess that is called a steering arm????
Old Apr 12, 2002 | 07:47 AM
RockyMountain250
Hey Abendx
[updated:LAST EDITED ON 12-Apr-02 AT 08:53 AM (EST)]Yea sounds good to me....
As for the boggers they are REAL loud, my buddie had a set of 31 12.50's on a cherokee and they were so loud that you had to yell to hear each other on the freeway. They also would shake the crap out of ya when you were coming to a stop. It was cool for a while but it got old real fast.
He would always say all you could hear was tires and tunes, and he was right you could here him coming a 1/4 mile away with those 2 12's and the boggers
swampa
Modular V10 (6.8l)
Mar 17, 2005 10:09 PM
FordPickMeUp
Offroad & 4x4
23
Dec 21, 2004 12:54 PM
FordPickMeUp
Offroad & 4x4
29
Nov 23, 2004 11:13 AM
offroadfords
Mar 19, 2004 08:40 AM
fordmaniac21
Apr 7, 2002 01:00 AM
