hpop
Old Aug 21, 2007 | 11:23 PM
stroken's Avatar
stroken
hpop
so my question is, do I need one? and what all does it do? i hear good about it but don't really understand why, and what it does...thanks guys
Old Aug 21, 2007 | 11:44 PM
Pocket's Avatar
Pocket
HPOP = High Pressure Oil Pump. It sits in the valley of the engine below the fuel bowl.
Our injectors are driven by oil pressure, and fired electronically. This is known as HEUI (Hydraulic Electric Unit Injection). Oil pressure is what atomizes the fuel. When you have a chip or tuner, you can raise the amount of fuel and increase the oil pressure to give you more power. The downside to this is that most of the time the stock HPOP isn't enough to keep up with what a hot chip demands.
So when you hear of everyone upgrading their HPOP, it means that they are going for a big oil setup. The ones you'll see are Terminator, Stealth, BTS, and Swamps. Each one is a bit (or a lot) different, but generally accomplish the same thing. Increase oil pressure and volume to the injectors. It's not a cheap upgrade, but it sure will wake up any engine.
Old Aug 21, 2007 | 11:53 PM
stroken's Avatar
stroken
so with my dp tuner this hpop will help out a lot? i was looking at the swamp..is that a well known good brand..?
Old Aug 22, 2007 | 12:03 AM
Tenn01PSD350's Avatar
Tenn01PSD350
I doubt you will need that until you step up to bigger injectors and turbo. And before I get hammered, yes, it will help but not as much as when you upgrade to the aforementioned items. If you plan to go that route, then giddyup.
Old Aug 22, 2007 | 12:11 AM
stroken's Avatar
stroken
yeah, my g/f brother has a 6.0 and hes getting stage 2 injectors and I can't let him have a faster truck so Im going with the stage 3 so i figured an hpop is needed but wasn;t positive...and turbo soon or later...plus i want the swamp deisel performance sticker..
Old Aug 22, 2007 | 12:35 AM
Tenn01PSD350
Well, let him get that, it will most likely be in the shop before you know it if it is like a lot of them. How hard is it to outrun that?
Old Aug 22, 2007 | 05:40 AM
Chance_Thomas's Avatar
Chance_Thomas
Not to still the thread but what order should you do it. I was thinking turbo, injectors then hpop. Please correct me if I'm wrong.
Old Aug 22, 2007 | 06:42 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
You'll have to accept the fact that he will be faster than you Kenny. WIth the type of rods you and me have in our engines, i wouldn't put a set of injectors in, or the way you drive, you'll be looking at a full engine rebuild which you don't have $$ for.
Old Aug 22, 2007 | 07:05 AM
Pocket's Avatar
Pocket
Then I'll hammer you now , in a non-sexual way
Upgrading the HPOP even on stock injectors can make a huge difference. My truck dropped .8 seconds off the 1/4 mile at the drag strip, and has tons of power in the upper RPM band. Before that, it would fall on it's face. Now that I've had live tuning this past weekend and Jody bumped the HPOP pressures to their max (now holding 3800 psi!!!!!!), I'm heading to the track this afternoon to see how much faster my truck is.
Also, sometimes when you upgrade injectors you end up using LESS oil. That's right, less. The stock injectors on our trucks are split shots, and most of the high performance injectors that are offered are single shots. Splits use more oil than singles, and when swapping out to singles suddenly the stock HPOP can keep up. Now upgrading the high pressure oil system can help both singles and splits, but you usually see a somewhat bigger gain on splits with higher oil pressure.
IMO getting a high pressure oil system is definately a great upgrade. As for how it compares to upgraded injectors? Well here's one for ya... The co-founder of the Colorado PSD Club owns a 2000 Excursion with a similar mods to mine including lift, but she's running injectors instead of an HPOP (I believe she has stage II's). She's running 15.2 @ 89 mph on custom tuning. Without custom tuning and my stock injectors I run 15.4 @ 86 mph, so I'm not far behind. Today I'll get to compare my time with custom tuning to see if I can beat her times. We'll see
Old Aug 22, 2007 | 05:50 PM
PowerstrokeJunkie
And JT harvey runs 15.0 on stock injectors as well.
Old Aug 22, 2007 | 06:38 PM
John311t's Avatar
John311t
I think that has alot to do with your preference, but the way i would go would be fuel sys, oil sys, studs, injectors and very shortly after turbo.
Old Aug 22, 2007 | 07:52 PM
SolidGround's Avatar
SolidGround
You'll need to have Jody do a rewrite with 'big oil' burns.
As for the Swamps, I know of a fiery story...
Just do your research and be ready to spend a couple grand +/-.
It's money well spent. In the long run you'll be able to run whatever sticks you'd like. Of course, you'll then need a bigger hairdryer
Old Aug 22, 2007 | 10:04 PM
jtharvey's Avatar
jtharvey
Indeed I do. And that's with off the shelf tunes too. I'd imagine if I had live tuning, times would drop below the 15's. The upgrade to dual HPOP's was one of the best mods I've done. The truck just drives and runs better throughout the whole RPM range. I got mine with plans to upgrade injectors, but knew there would be a benefit on stock injectors...I just didn't expect it to be as noticeable as it is.
Old Aug 22, 2007 | 10:18 PM
PowerstrokeJunkie
I keep spending a few hundred here, a few hundred there on misc stuff and if i stopped for a month i'd have big oil!
Old Aug 22, 2007 | 10:31 PM
jtharvey's Avatar
jtharvey
Well then...STOP! Get youself some BO!
