Help! Trucks Dead!
Old Aug 21, 2007 | 08:08 PM
jetdoc's Avatar
jetdoc
Originally Posted by THE KING
The batterys are good. The green bulbs are still there.
Put a meter on it when you crank it. I know that these trucks NEED two good batteries. If one is bad it wont start.
Old Aug 21, 2007 | 08:13 PM
Action4478's Avatar
Action4478
That is not a very good test.....
Old Aug 21, 2007 | 08:28 PM
THE KING's Avatar
THE KING
One dead battery would make the whole truck go crazy? Relays clicking like non other?
Old Aug 21, 2007 | 08:48 PM
F350-6's Avatar
F350-6
Lights flashing and needles moving on the dash sounds like a PCM reset. Check the battery and ground connections really well.
If you leave the key on in the run position, which lights on the dash stay on?
Old Aug 21, 2007 | 10:02 PM
bdrummonds's Avatar
bdrummonds
Yep. One or both batts are toast, and your alternator is probably dead too. Before paying dealer to tell you this (and overcharge you) Get two new batts and replace them. Start truck drive back to Autozoo have alt. tested,and buy a NEW lifetime warranty alternator. 3 bolts 2 wire connections and your done.
$150 for batts. ~$180 for alt.
yeah I know it sounds crazy, but I have been through this before same symptoms. interior lights all flashing sounds like hazards are cycling, dash lights blinking. Been there done that got the t-shirt to prove it.
LOOk HERE https://www.ford-trucks.com/forums/6...-problems.html
Old Aug 21, 2007 | 10:51 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Parts store cannot usually scan for our codes. Non OBDII compliant. They can load test batteries and the alternator. I say you may need new batteries and then have the alt tested as previously mentioned. How old are the batteries?
Old Aug 22, 2007 | 07:46 PM
THE KING's Avatar
THE KING
Too late, My dad needs his truck asap and he couldnt wait for me to get home to work. SO now hes having the stealership fix it. I wonder what they come up with?
HD
13
Jan 9, 2016 07:05 AM
98F150on33s
1997 - 2003 F150
Nov 26, 2014 11:28 AM
1badcj8
Feb 24, 2013 02:06 PM
ozutah
Oct 7, 2008 08:59 AM
BAMBIBLASTER
Sep 1, 2007 03:17 PM
