95 E150 Van Won't Start
Old Oct 23, 2007 | 08:37 AM
Clubwagon's Avatar
Clubwagon
Dropping the tank isn't hard, as long as it isn't full ;-)
When I did the pump in mine, it was in my shop. I had a lift and a pair of transmission jacks to support the tank. Very easy. Later, I did the filler tube in my driveway. I used a floor jack with a wide plank on it to support the tank. Then released the straps and lowered it for access.
To get the pump out I am sure it would be easier to have the van sitting on stands but I didn't have to just to change the tube.
Steve
'05 Clubwagon XLT
Old Oct 29, 2007 | 07:49 AM
Auztone's Avatar
Auztone
Update:
Well I tackled this job yesterday and didn't have great results. Replaced the pump and it failed to run. I made sure even after I lowered the tank that I had power back at the connector. I was also very carefull that the polarity was correct on the pump when installing. I'm guessing that I got a bad pump from the parts store? This really sucks as this was not difficult (other than getting the fuel lines off) but time consuming.
Anyways, it looks like I'm going to drop the tank and replace the pump again. I will probably try and start it on the bench after I remove it. If it starts then I don't know what the problem might be.
Thanks
Old Oct 29, 2007 | 08:13 AM
subford's Avatar
subford
This sounds like a bad ground at G101 in the engine compartment, take the ground wire off coming from the fuel tanks, clean the body with sandpaper and put the wire back on the body.
Ground G101.
EconolineFan
22
Jan 15, 2018 03:47 PM
Lesa Garballi
Jan 22, 2016 10:19 AM
t mango
13
Jun 3, 2015 09:35 PM
Powermonger
24
Dec 1, 2011 01:30 PM
andrewzx92000
Apr 14, 2011 08:28 PM
