Bronco II Ford Bronco II
Tank size...
Old Aug 21, 2007 | 01:25 PM
1986BII's Avatar
1986BII
Question Tank size...
Hello all. As some of you may know, I have a '86 Bronco II Eddie Bauer. I've read in a few places that it has around a 23 gallon tank. I ran it down 'til the Low Fuel light lit up, and the kneedle was right on top of Empty. I put 2 gallons in it, and it filled it to a hair under half a tank on the meter... When I filled it all the way up a few weeks ago, when it was a hair under half a tank, it took 15 gallons... Any thoughts on tank size? I think it's a 17 or 18, but I could be wrong. I don't think that it will run on empty equivelent to another 6 gallons...
Old Aug 21, 2007 | 08:27 PM
my72ford's Avatar
my72ford
i believe all bII's from 86 on up had 23 gallon tank...i think the 84-85 had an 18 gallon...if memory serves me correct
Old Aug 21, 2007 | 09:56 PM
fl1a's Avatar
fl1a
Many times when the fuel sender fails on Bronco II's, the gauge will drop off sharply
after reaching the 1/2 tank level.
Old Aug 22, 2007 | 05:34 AM
powrstrkr's Avatar
powrstrkr
It's a 23 gal tank. The sending units fail like that. Mine did. You can replace the guts inside the tank as a unit. They install from the top of the tank. Tank is easy to remove. Skid plate, 2 straps and it falls out.
KDAVID1
Feb 16, 2015 05:55 AM
jor1369
2009 - 2014 F150
Jun 15, 2014 09:02 PM
One Sock
Jun 12, 2014 07:36 PM
Schmids4.9l
15
May 22, 2005 11:53 PM
