Hydroboost?
Old Aug 21, 2007 | 08:39 AM
Pele's Avatar
Pele
Hydroboost?
So I think I have to replace my power steering pump:
https://www.ford-trucks.com/forums/6...eshooting.html
I looked at replacements, there appears to be options with and without hydroboost.
I wasn't aware that hydroboost was available for these trucks. I thought it was a Chevy thing only.
Where can I source a Hydroboost actuator? Will I need to swap anything else out? Or is it simply just remove the master, remove the booster and plug 'n' play?
I'd love to ditch the Vacuum pump and run a second alternator or an air compresor in that area.
Old Aug 21, 2007 | 10:12 AM
lartross's Avatar
lartross
I converted my '90 f250...had to purchase 2 new hydraulic hoses, hydroboost p.s. pump, hydroboost unit, and, since the hydroboost may have more push, I bought a new master cylinder [probably not necessary]. I had to do a little hole modifying to make everything fit together, but, it works fine and I no longer worry about losing a vacuum pump and losing my brakes. I still need the vac pump to run the heater stuff.
Old Aug 21, 2007 | 01:13 PM
Pele's Avatar
Pele
What's the hydroboost pump have that the non-Hydroboost pump doesn't?
I'm thinking of getting a Hydroboost and waiting till I find a hydroboost unit on another vehicle.
Old Aug 21, 2007 | 03:08 PM
trackspeeder's Avatar
trackspeeder
Return for the boost unit.
Old Aug 21, 2007 | 04:05 PM
Pele's Avatar
Pele
Interestingly, CarQuest only specs two pumps, there's a year cutoff date based on the production month.
I suppose I could "T" into the return if there is only one or cap off the unused if there are two... It may be like radiators, where they all have a set of transmission cooler fittings, but you only use them if you have automatic.
Their rebuilder is Cardone.
Old Aug 21, 2007 | 10:27 PM
Dave Sponaugle's Avatar
Dave Sponaugle
A 97 F450 hydroboost will bolt right up.(E8TZ-2005-B)
Use your old master cylinder, the 450 had rear disc brakes.
My master cylinder bolted right on without any mods.
Three hoses, (F4TZ-3A714-A, F4TZ-3A717-A, E8TZ-3A713-B)
PS pump to hydroboost
Hydroboost to steering gear
Return line from hydroboost to PS pump
And a different reservoir for the power steering pump that has an extra return line fitting.(You could probably tee the return lines together)
Two hours swap time.
Four times the stopping power.(guess)
And yes, you still need the vacuum pump to make the heater switch from defrost to any other air discharge position.
Old Aug 21, 2007 | 10:56 PM
catfish101's Avatar
catfish101
[/QUOTE]
And if you are doing this much work get the electric vacuum pump off of a late model so you can get the belt driven pump off the motor..This will free some HP's.
Old Aug 22, 2007 | 03:52 AM
Pele's Avatar
Pele
For the heater controls, there's a vacuum pot on the passenger's side firewall, just above the blower motor.
Where is the other one?
Which does which?
I've seen the electric motors for other vehicles (My Mazda RX-7, several others) that may adapt fairly easily.
Or I can "T" into the suction end of my York air(conditioning) compressor that I'm planning on adding.
Old Aug 22, 2007 | 07:40 PM
trackspeeder
You can use a pump from a superduty or convert your pump with the parts from Ford. About $35. bucks and an hours worth of your time.
Old Aug 22, 2007 | 08:51 PM
Pele's Avatar
Pele
I got a rebuilt pump with the correct resivour from CarQuest.
I'll just leave the hydroboost line capped off for now until I can find a Hydroboost unit at the scrap yard. Core charge is a bit high, and I don't think they'll appreciate a Vacuum booster in the box that the Hydroboost came in.
Old Aug 22, 2007 | 10:29 PM
Franklin2's Avatar
Franklin2
Just as a side note, the newer mustangs use a hydroboost setup. A guy I work with had a 2000 cobra convertible, and had to take it back to the dealer because every time he hit the brakes, the steering wheel would jerk a little bit.
okie72
Feb 15, 2014 09:35 PM
F250racer
Feb 17, 2011 03:58 PM
therigwelder
Jun 21, 2009 08:18 AM
Finally
Sep 26, 2004 10:30 AM
