Aerostar Ford Aerostar
Speedo went bang
Old Aug 20, 2007 | 06:09 PM
buzzer691000's Avatar
buzzer691000
Speedo went bang
I was changing radio in our 89 ford Aerostar when my wife started the van and the Digital speedo went out. The back light works and the rest of digital dash works fine. I have replaced all light in back and replaced every fuse in box and nothing. I also replaced the digital dash and the replacement didn't work either. The upper trip thing above rear view mirror doesn't work either. I have run out of ideas.
Old Aug 21, 2007 | 02:31 AM
DCRB's Avatar
DCRB
did you cut the wireing harness for the radio? if you did, that may have effected it...
Old Aug 21, 2007 | 09:10 AM
buzzer691000
I used a replacement radio from ford plugged right in didn't cut any wires
Old Aug 21, 2007 | 10:04 AM
cookkd's Avatar
cookkd
There is a common "switched power" input to the multifunction gauge and the trip minder. On my 90 and 91 it is a pink and black wire coming from the fuse block. It is fused by a 10a fuse (No 17).
Old Aug 22, 2007 | 07:09 PM
buzzer691000
well thanks after reading your post i checked the fuses with a pwoer tester. The power for the Speedometer is routed through the Dome light 15a fuse. I changed and every thing works now. Thanks for your help
bigcountry25
Electrical Systems/Wiring
Oct 4, 2013 06:52 AM
Rugar
15
Nov 14, 2010 01:15 PM
jetdoc3037
51
Jan 26, 2008 11:29 PM
jayrak
Apr 30, 2004 01:39 AM
jayrak
Feb 21, 2004 11:33 PM
