Sponsored by: Real Truck
Dash warning lights
Old Aug 19, 2007 | 09:50 PM
Ford Trucks #96's Avatar
Ford Trucks #96
Question Dash warning lights
Just wondering what the norm is? When i turn the key on most lights come on then go out . Sometimes i see the wrench other times not. Sometimes the engine light stays on till i start the truck,sometime's not . One light i've never seen is the water in fuel.
Old Aug 20, 2007 | 01:25 AM
LvTitan's Avatar
LvTitan
i always see the water in fuel when i key on, but it goes out right away, never really paid attention exactly to which lights come on at power up.
LvTitan's Avatar
LvTitan
i do believe the users manual tells you exactly what lights you should see upon power up, read that and compare it to what you actually get.
Old Aug 20, 2007 | 08:27 AM
redford's Avatar
redford
FTE Leadership Emeritus
They should all come on when you first turn on the key, as a bulb test.
From the 2004 Owner's Manual:
Warning lights and gauges can alert you to a vehicle condition that may become serious enough to cause expensive repairs. A warning light may illuminate when a problem exists with one of your vehicle’s functions. Many lights will illuminate when you start your vehicle to make sure the bulb works. If any light remains on after starting the vehicle, have the
respective system inspected immediately.
Old Aug 20, 2007 | 04:55 PM
LvTitan's Avatar
LvTitan
there's your answer. in my vehicle (o4 crew cab ) my water in fuel light is yellow and in the top left corner of gauge cluster. almost like the low fuel light, it looks a fuel pump with about 3 rain drops falling on it
Old Aug 20, 2007 | 08:34 PM
Ford Trucks #96
mine never lights up ,but it should for a second ??? Right
Old Aug 20, 2007 | 11:17 PM
LvTitan's Avatar
LvTitan
yes it should when you first turn the key on
Old Aug 21, 2007 | 08:44 PM
Ford Trucks #96
is there a TSB on it??
fancyvern
Nov 2, 2012 03:34 PM
tmartin2
Jul 19, 2011 11:05 AM
tim nick
1997 - 2003 F150
Jul 5, 2007 09:45 AM
nobodyspecial
May 21, 2007 01:58 PM
ktm520mxc
Aug 13, 2004 11:52 PM
