Sponsored by: Auxito
Keypad
Old Aug 18, 2007 | 09:44 PM
bigal1's Avatar
bigal1
Keypad
My key pad works intermittently. I cant ever guess when it is going to work.It is unreliable.
I have read some previous post on this subject but I still dont know where to start.
When it dont work:
Enter code and the driver door and the passenger door just jumps a little.It will not lock or unlock,just jumps a little.In the near past,the driver door would not work but the passenger door would.
When it works it works perfectly.
Cant determine a direction to take to diagnose the problem.Any ideas?
2000 F-150,5.4L
Old Aug 19, 2007 | 06:47 AM
ncranchero's Avatar
ncranchero
Does it work ok from the remote fob and/or by manually pressing the inside buttons?
Old Aug 19, 2007 | 03:44 PM
bigal1's Avatar
bigal1
The keyfob follows the same pattern. When it works all is working. when it dont, nothing works. The door lock buttons just jump a little.
Old Aug 19, 2007 | 04:31 PM
ncranchero's Avatar
ncranchero
Sounds like the typical weak lock actuator problem. Low battery condition can also cause them to not work properly.
Old Aug 19, 2007 | 05:27 PM
myxr's Avatar
myxr
If your interior light does not funtion when you've completed your password, then the contacts on the number pad is most likely dirty or corroded. This was the case in my supercrew, and I removed the interior door panel (no easy job) and took a pencil errasor to the contact points behind the number pad. After 2 years, the problem has returned though.
Old Aug 19, 2007 | 06:01 PM
ncranchero's Avatar
ncranchero
Ford had a lot of water contamination problems with the keypads and that was my first thought also. But he says the fob duplicates the problem too......
Old Aug 20, 2007 | 11:54 AM
mattyk6_bdr's Avatar
mattyk6_bdr
It's the door lock actuators. Do a search and you will find several threads on it. The first door is a little tricky, but the second will be easier. The first door took about 3 hours, the second took about 30 minutes.
polarisman
2004 - 2008 F150
Apr 22, 2014 11:48 AM
totalrecall
17
Sep 4, 2012 02:27 PM
mikren
1997 - 2003 F150
28
Aug 22, 2009 09:39 AM
lynnville3060
1983 - 2012 Ranger & B-Series
Sep 25, 2006 10:38 PM
Wakeboarder141
1978 - 1996 Big Bronco
Jul 12, 2003 09:19 PM
