Sponsored by: Auxito
engine chuggs
Old Aug 19, 2007 | 07:41 PM
RJs dad's Avatar
RJs dad
Thumbs up engine chuggs
I have a 2001, 4.2 ltr. Last week I filled up and two days later my engine, when given gas has started to chug, it idles fine and as long as you are cruising at a c ertain speed its fine. I burned half of that tank and refilled with 93 octane, plus put water displacement in my tank thinking i may have bad gas. I have also changed out both O2 sensers, thinking they may be my problem. Any suggestions before I take it to the shop.
Thanks
Old Aug 19, 2007 | 08:15 PM
40LUTZAG's Avatar
40LUTZAG
Probably bad packs, wires and plugs.
I have first hand experience with bad chuggs. Ive replaced two coil packs on the drivers side, and one on the left. All plugs changed and wires. All went away. A while later shuddering came back engine code read cyl#4 misfire. Bought new wires from Ford and they gave me a wire 2" shoter than original. still drives like crap. Suggestion check all plugs wires and caps.
Old Aug 20, 2007 | 12:30 PM
RJs dad's Avatar
RJs dad
Do you thinking changing my sparkplugs and wires would get rid of my problem. If so do you know how difficult they are to change on a 4.2 ltr ?
