1978 - 1996 Big Bronco
Door activated dome light
Old Jul 11, 2003 | 12:18 PM
Wakeboarder141's Avatar
Wakeboarder141
I noticed last night that my dome light no longer turns on when I open my drivers door. The passenger door works and I can see the little button on that side. Where is the button that activates it on the drivers side? I was working in semi darkness but could not find it. Anyone know of any reason this would stop working?
P.S. Did the clasified forum get taken away? I want to sell my roll bar but can't find where to post it. Thanks.
Old Jul 11, 2003 | 01:15 PM
pezley69's Avatar
pezley69
Well, on my 96 it is on the inside of where the door closes near the hinges. I would assume yours is the same. Maybe in the daylight you will be able to see it. Or maybe it broke off? It screws in on mine. Hope this helps.
Old Jul 11, 2003 | 01:59 PM
steve83's Avatar
steve83
Sounds like it broke. It's in the same spot as the R side, and looks identical. It'll be a pain to fish it back out because you have to remove the big aluminum e-brake pedal bracket (after dropping the steering column) to get into that kick.
Old Jul 11, 2003 | 02:39 PM
Wakeboarder141
Well I found it in the light. On the drivers side it is actually different than the passenger side. On the D side it is below the striker bolt as opposed to on the side with the hinges. I think I may have a loose connection because after playing with the button for a bit I got it to work again. Thanks.
Old Jul 11, 2003 | 03:08 PM
JBronco's Avatar
JBronco
Those ground to the sheet metal. If it is loose or just not sitting right, it won't ground. Usually these are fixed the same way yours was, by messing with it for a bit. If you want to be sure of it, unscrew it and sand down the area where it touches the door, and screw it back in.
Old Jul 12, 2003 | 01:41 PM
steve83's Avatar
steve83
That's weird. My '96 Bronco had both by the hinges.
Old Jul 12, 2003 | 07:56 PM
joebronco94's Avatar
joebronco94
Boht of mine are on the hinge side also it's a 94 . Mine screwed up and wouldn't turn the light off. got new swithes at auto zone for around 5$ apeice
Old Jul 12, 2003 | 09:19 PM
Black Ford XLT's Avatar
Black Ford XLT
Ive replaced my switch once on my 92 ;they can go bad ,also check the ground ;good luck TR
Derrrrick
15
Feb 6, 2017 01:56 PM
ligito
Oct 19, 2016 02:15 PM
ZombiePopper
Oct 5, 2014 09:27 AM
rpstrong
Dec 13, 2013 06:47 PM
elbatman22
1997 - 2003 F150
Oct 31, 2010 06:47 PM
