Any PSOM guru ????
Old Aug 18, 2007 | 11:31 AM
javi2001's Avatar
javi2001
Question Any PSOM guru ????
Hi all, recently I bought half F150 truck in a local yard, the idea is switch the whole passanger cab with wiring and everythig, but I'm going to have a problem:
1º The new cab has the standard English speedmeter with MPH graphics, but I live in Venezuela and we use Metrics and Km/H grapics, the question: Is it possible reprogram the PCM to show Metrics readings on speed meter and Odo?? no mater the graphics, I can take care of that with help of a local graphics design company.
2º The total Odo reading can be reprogramed also to mach my actual truck reading ???
3º I'll have to reprogram also the constant because I'm using 31/105R15 LT tires, I know there are a lot of articles about this but someone knows whitc is the constant I should program?
Thanks all, any help/comment will be appreciated.
Old Aug 18, 2007 | 04:09 PM
subford's Avatar
subford
Just swap your old PSOM with the one in your new cluster.
Old Aug 18, 2007 | 10:01 PM
javi2001's Avatar
javi2001
Hey SubFord, thanks for the imput BUT that's not posible, because my truck is 1986 and there is no PSOM used on that cluster. Sorry I forgot menction that...
MY truck is 1986 but the new cab to be installed is 1995...
Any more ideas guys???
Old Aug 19, 2007 | 09:27 AM
Franklin2's Avatar
Franklin2
Are you swapping more than the cab? If you don't have the differential or the tranny(don't know which one that year) with the speed sensor, I don't think it's going to work anyway. It's fully electronic with no cable correct?
Old Aug 19, 2007 | 11:41 AM
javi2001's Avatar
javi2001
I'm swaping just the cab and all the front, bumber, fenders, etc but my rear axle was changed 2 years ago and it already has de VSS installed.
Old Aug 22, 2007 | 06:57 PM
lostin90s's Avatar
lostin90s
got to articles/specs above . they have how to change speedo from met to stan . and rest it to be calibrated to tire sized. Good luck Believe its in instrument cluster. I'll try to find if you don't .
As for the odom its a Ford only thing I believe. lost
Old Aug 22, 2007 | 07:14 PM
lostin90s's Avatar
lostin90s
got to articles/specs above . they have how to change speedo from met to stan . and rest it to be calibrated to tire sized. Good luck Believe its in instrument cluster. I'll try to find if you don't . I can access the area but can load any thing . Its in cluster install,charts and codes or featured articles . Sorry I could not dig up for you . Itwas posted just week or so ago on 87-97 forum . I'll try tomarrow
Old Aug 24, 2007 | 06:50 PM
javi2001's Avatar
javi2001
Well I'm talking to my local Ford dealer trying to get a new totally programed cluster, BUT it will be very difficult since here in Venezuela, electrical/electronics support was/is almost null...
Old Aug 25, 2007 | 01:24 PM
lostin90s's Avatar
lostin90s
Hey I looked and can't get it to load . I'll try later
ez1134
May 23, 2017 06:44 AM
robert_l_ross
Feb 28, 2017 02:10 PM
mudder460
17
Sep 23, 2016 11:13 PM
tjc transport
27
May 9, 2010 10:19 AM
patagonia.man
Sep 9, 2003 11:19 AM
