Under the Valve Covers
Old Aug 17, 2007 | 09:36 PM
cdiddy's Avatar
cdiddy
Since I have the turbo out I thought it would be a good time to change the glow plugs and check out the wiring under the valve covers. I was wondering if it was ok to reuse the valve cover gasket? Im also going to check on the rocker bolts and injector bolts and retorque them but do I need to retorque the head bolts and if so does any one know the torque setting on them.
Old Aug 17, 2007 | 09:46 PM
c00nhunterjoe's Avatar
c00nhunterjoe
no need to retorque any of it, no need to replace the glow plugs unless they dont ohm out, inspecting the uvc harness isnt a bad idea and yes the gaskets are reusable unless of course they are melted
Old Aug 17, 2007 | 09:54 PM
FN74's Avatar
FN74
Good thinkin. You may as well replace your Glow plug relay while your there. Yes you can reuse your Valve Cover gaskets. Just when you are all done make CERTAIN the electrical connector on the inside is seated properly. The torque spec for the Rocker arm bolts is 20lb-ft. You shouldn't need to worry about the head bolts, but if you so desire, the spec for those is 95lb-ft. Would also be great time to throw in a set of Stage 2 or 3 injectors....
Old Aug 17, 2007 | 10:08 PM
cdiddy's Avatar
cdiddy
I would love to replace the injectors but my wife is about to kill me right now. Im already replacing both front hub assys and I figured with the amount of miles that I have I should rebuild the turbo and also do a little up grade to it as well and I cant forget the gauges that I need to keep an eye on it so I would just like to inspect and make sure everything is ok for now.
Old Aug 17, 2007 | 10:10 PM
cdiddy's Avatar
cdiddy
P.S. is the torque for the injectors 120inc/lb?
Old Aug 17, 2007 | 10:27 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
yes, 10 lb ft or 120 inches.
Old Aug 17, 2007 | 11:10 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Based on what I have seen, definately snug/torque the injectors and rocker arms.
Old Aug 17, 2007 | 11:29 PM
cdiddy's Avatar
cdiddy
is there only one bolt for the injectors? Is it on the bottom of the injector? And there is only 4 bolts for the rocker arms right?
Old Aug 17, 2007 | 11:48 PM
cdiddy's Avatar
cdiddy
is it normal for the injector bolts to be loose? The are turning quite a bit like they were not even tight. All of the rocker arm bolts were tight but is 20lbs of torque enough? It does not seem like much for a rocker arm.
Old Aug 17, 2007 | 11:52 PM
Tenn01PSD350
I have yet to get into mine. Dan, aka Kwikk has done this so hopefully he will respond to this in the AM.
Old Aug 18, 2007 | 04:34 PM
cdiddy's Avatar
cdiddy
Is the bolt that needs to be torqued to 120in/lb right under the injector? There is only one right?
Old Aug 18, 2007 | 06:48 PM
1996pwrstrk's Avatar
1996pwrstrk
Yes there is only one bolt on the injector.
jhobbs26
13
Apr 21, 2013 12:42 PM
cutlass
Sep 21, 2012 01:02 AM
nothercrash
Apr 5, 2011 10:12 PM
BigJake34452
Jul 27, 2010 09:57 AM
Kwikkordead
21
Dec 30, 2006 11:17 AM
