Edge Platnium shifting woes
Old Aug 17, 2007 | 05:27 PM
nybucketman's Avatar
nybucketman
First off, hi all. This is my first day as a member and on the site. I absolutely love it.
Real quick, I have an 06 F-350, CC, longbed, 4X4, 6.0 and torqueshift with 18,000 miles. Upgrades include edge juice platnium, aFe intake and aFe 4 inch catback duals with 5 inch tips.
When I run tune 5, extreme, or tune 6, hot, the transmission shifts poorly, to say the least. It has even failed to start in first gear a few times. I actually thought I smoked it at half throttle from a standstill. I have tried re-learning the trans with no luck. Is there a fix for this? Anyone on this site run the edge juice platnium? I have the trans safety features enabled, TC lockup, TC slip protection, etc, but they don't seem to be working. Thanks in advance for all the help. Chris
Old Aug 17, 2007 | 05:32 PM
npccpartsman's Avatar
npccpartsman
If you'll do a search for the EDGE products you'll see the consensus is that the edge will cause you tranny problems, poor shifting, etc. Despite what changes they've made to it it still gives problems. Your best bet would be to sell it and get an SCT programmer that will properly tune your engine and transmission by reprogramming the PCM and TCM instead of fooling them with the plug-in module.
Old Aug 17, 2007 | 05:36 PM
nybucketman
Thanks alot for the advise. Are you interested in a slightly used Edge Juice Platnium with Attitude, LOL. Chris
04Xcursion's Avatar
04Xcursion
Welcome to the forum...
Have look at this thread:
https://www.ford-trucks.com/forums/640572-edge-juice-the-bad-stuff.html
I think it will give you a few ideas about why your truck is doing what it is.
Old Aug 17, 2007 | 07:21 PM
Reave1's Avatar
Reave1
Have a buddy that went through 5 trannies with the edge. That in line tuner has some bad mumbo jumbo. Cut your losses now and get a custom tuned SCT. Overall you will lose the investment of the edge, but it will save you thousands in trannie replacement cost. The SCT is a great tuner, and I was very skeptical. Boy was I wrong! this is the best tuner I have ever used.
Old Aug 17, 2007 | 10:09 PM
nybucketman
Thanks guys for all the help and information. I will be removing my edge platnium tomorrow and looking for an SCT programmer. Chris
Old Aug 18, 2007 | 09:28 AM
04Xcursion's Avatar
04Xcursion
Don't forget gauges... You'll need 'em
Old Aug 18, 2007 | 09:44 AM
6.0superduty's Avatar
6.0superduty
nybucketman, talk to Matt at Spartan Diesel Tech and he will hook you up. You can get all the info off of his site too. Its www.spartandieseltech.com
Old Aug 18, 2007 | 03:52 PM
07Dually's Avatar
07Dually
nybucketman,
I would talk with Matt before removing the Edge. I read a post of his recently where he said that the Edge w/Juice could be set on "0" and used as gauges while running his tunes via the SCT. That way the Edge would not be a total loss.
Charlie
Old Aug 18, 2007 | 09:42 PM
daddgonemadd's Avatar
daddgonemadd
I switched to Matt from Edge, and for a few weeks I used the Attitude for my gauges set to zero. That will work, but now I have dedicated gauges, and have to pawn off my Edge stuff to someone on Ebay.
Old Aug 18, 2007 | 11:40 PM
nybucketman
daddgonemadd,
What do you use for a turbo timer? I plan to get a remote starter/car alarm, I guess I can spec one out with a turbo timer. Chris
Old Aug 18, 2007 | 11:42 PM
freeride808's Avatar
freeride808
I have been running my A2 with Matt's tunes. Everything has been so much better since the change. Set the Edge to 0 and go go go.
nybucketman
Thanks again everyone for all the great information. I will be notifying Matt shortly. From my reading, he appears to be extremely busy. Hopefully he will have some time in the next couple of weeks to hook me up. Chris
Old Aug 20, 2007 | 07:57 AM
daddgonemadd
i don't have a turbo timer. I just wait till the egt is below 400 to shut down. My remote start has a built in delay for diesels for the glow plugs. I think most have that option.
pdklr
Mar 15, 2014 06:26 PM
amsk8er1983
Jul 30, 2009 07:12 AM
hornsfan
Aug 14, 2007 06:54 PM
hornsfan
Aug 13, 2007 04:49 PM
great white
20
Oct 4, 2004 12:55 PM
